BRAKE light on 3 weeks. Fluid level is ok...
It was snowing 3 weeks go and I get problems. First alarm went off randomly but it is solved with disconnecting hood sensor. https://acurazine.com/forums/3g-tl-2...light-1006192/ . At same time BRAKE light turn on but obviously do not have connection with first problem. I did clean switch for brake fluid level and add dielectric grease. What else could be problem, maybe switch for emergency brake I should check? All brake lights are working.
3 months later same problem exist. Went to car part store a few months go and they say they can not read "BRAKE" code. It is clearly, I can hear it when drive and even feel when put hand at emergency brake handle protection, something detached in that area of emergency brake handle, like some thin wire. Will need to open center console to see what is going on.
Paring brake work for sure I can feel under hand when pull it but wire that connect to switch look detached.
OUTRAGEOUS CL TYPE S
12-18-2003 12:51 PM
