Brake calipers
Old Feb 3, 2009 | 11:40 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
Brake calipers
Whats a good brake caliper paint to buy... I want to paint mines black but i want it to look like real paint
Old Feb 4, 2009 | 01:36 AM
tc_terencec's Avatar
I MAKE NO SENSE
I haven't personally tried but I have heard some really good things about duplicolor... maybe members who have tried this can confirm this?
Old Feb 4, 2009 | 02:07 AM
01tl4tl's Avatar
yes duplicolor kit for 10 bucks is great, used by many here
I use it on the 01TL
Kit contains spray cleaner-tape-brush and paint thats temp safe to 600 degrees F
If your caliper is that hot,,,a tree is probably looming in the windshield~
Old Feb 4, 2009 | 02:21 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
clear coat?
Old Feb 4, 2009 | 03:51 AM
hata_61's Avatar
make sure the caliper is really clean, and if you are really hard core then take the pads out, unbolt the caliper from the knuckle, mask everything off before you go nuts with the paint!! good luck!
Old Feb 4, 2009 | 04:45 AM
01tl4tl's Avatar
Duplicolor is colored high temp paint, not a clearcoat, and it comes in spray paint can or liquid form with brush. I prefer the liquid for less mess and masking with more finite control on the edges
It last pretty well with 3 coats, Just a little touch up before an azine meet~ and all is good
The spray cleaner in the kit works good. I use a wire wheel on a drill or some sandpaper to rough the caliper surface for even better adhesion of the paint
Remove the calipers and pads from the mounting bracket, paint the bracket too
That way you dont wash away the special grease on the pads and in the caliper slides
Never hurts to do a real brake pad inspection anyway and regrease the sliding bits
Duplicolor gloss black will make plain rear calipers look like brembo fronts
Standard caliper cars paint the front and rear for a stealthy sports car look. With the small size of the calipers- painting them bright just draws attention to the fact they are stock.
IMO- stealth them black
You can also paint the edge of the rotor and its center hub and edge where surface rust always forms on the bare metal ---then it wont!
Old Feb 4, 2009 | 06:11 AM
LoveMyTL-S's Avatar
Here's an interesting thread to read:
https://acurazine.com/forums/3g-tl-2004-2008-93/d-097-diy-painting-factory-brembos-red-white-acura-logo-640092/
Old Feb 4, 2009 | 08:27 AM
BEAR-AvHistory's Avatar
Did mine in black to match the fronts....used a brush & did not have to take them off or mask them.
Old Feb 4, 2009 | 08:29 AM
LoveMyTL-S's Avatar
That's how I did my calipers on my old TSX. Painted them red and used the Duplicolor kit. Worked great and had enough left over to do another set of calipers.
Old Feb 4, 2009 | 11:20 AM
01tl4tl's Avatar
Its possible to paint the calipers with them installed,
I wanted everything to match so the brackets were done at the same time
check gen2 DIY or gen3 garage sections for detailed info on how to use masking tape and a small paintbrush~
Old Feb 4, 2009 | 04:16 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
would it be corney if i put brembo decals on the calipers or should i just do somethign like WDP UA6 or my car club name ON DA LOW
Old Feb 4, 2009 | 04:22 PM
Trew's Avatar
please dont...
mglax13's Avatar
New shoes on my
The brembo would be rice-ish, but the other ones would be cool. I think your car club would be cool.
Old Feb 4, 2009 | 04:52 PM
rockyfeller's Avatar
King of NYC
G2 paint is supposed to be the best DIY kit but is a bit pricey. I can vouch for Dupli-color, it's <$20, brush on and good quality stuff. The kit comes with all you need.
Old Feb 4, 2009 | 06:51 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
20 for one can?
Old Feb 4, 2009 | 06:56 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
where do i get this from?
Old Feb 4, 2009 | 08:59 PM
01tl4tl's Avatar
duplicolor kit with all you need for 2 cars or more, is 10 bucks at any parts store
red is cool if you have actual big brakes to show off
Black is for hiding tiny stock brakes and keeping the rust look away!
Brembo stickers??? only enough room for BREM on the calipers~
Paint em black and call em Bimbos or Blembos
Old Feb 4, 2009 | 09:06 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
spray paint right?
Old Feb 4, 2009 | 09:17 PM
mmade22's Avatar
200,000 mile club
To do it right, you should take the brake pads out, tape and clean all parts, sand all areas and paint it with the right high temp paint. Please, Please, Please don't put Brembo on a standard A/T car. What's next a type-S logo on the back of your base TL?
Old Feb 4, 2009 | 09:19 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
nah, i was thinking UA6
Old Feb 4, 2009 | 09:21 PM
ac08odl's Avatar
ON DA LOW CAR CLUB
never mind i though u were talking about the back calipers
Old Feb 4, 2009 | 11:47 PM
01tl4tl's Avatar
You can buy it as a spray paint but I prefer the liquid paint can kit as I described before.
10-12 dollars and has big spray can of cleaner (like carb cleaner) to remove dust and grease.
Since its important to maintain the grease at the caliper-pad contacts I remove the 2 bolts and pop the caliper off the bracket.
That lets you do a brake pad inspection while you are in there- check pads and rotors -clean out the old grease and relube with synthetic hi temp brake caliper grease
Old Feb 4, 2009 | 11:50 PM
01tl4tl's Avatar
There is an other option:
BBQ- barbeque paint, in flat or gloss black- same temp rating of 500-600 degrees and cost 5 bucks
If you own a can of brake cleaner, sandpaper, tape etc, thats another way to go
You can spray some paint into a cup and use a brush too, if needed
On guy had his calipers powder coated!!
ac08odl's Avatar
ON DA LOW CAR CLUB
do your know what is the pressure on the mounting screws that you took out? and i think im going to go with the spray paint i hear its better....
Old Feb 4, 2009 | 11:56 PM
01tl4tl's Avatar
check kragen.com for exact specs- my gen2 was about 50 foot pounds front calipers and 18 rear calipers- they have a much smaller bolt
you can be a human torque wrench- press down on the wrench and feel how much muscle effort it takes to try to move it more,,- now remove it feeling how much effort.
careful!!! not to overtighten bolts with an air gun like the shop does- those guys ruin cars~
Old Feb 5, 2009 | 12:00 AM
01tl4tl's Avatar
to each his own way--
if you buy a spray can get a few flux brushes or small foam brushes just in case you need to switch methods
Excess paint in the air can get on everything- thats a main reason I like the brush, control
With brush you can easily do the brackets and the center of the rotor where its rusty
Old Feb 5, 2009 | 12:27 AM
ac08odl's Avatar
ON DA LOW CAR CLUB
you know what you right............... but i dont know the spray has more of a gloss look to it dont u think
Old Feb 5, 2009 | 07:18 AM
LoveMyTL-S's Avatar
The spray would be more glossy looking (better looking imo). Just don't let it run.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
