Time for brakes on 2 06 MTs. Is there an aftermarket alternative to this tool or another method of compressing the pistons on the brembo ? If needed where do you buy it ? thanks much sa
nfnsquared
close
- Join DateDec 2003
- LocationMAGA country
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,824 Times in 1,370 Posts
Screwdriver with a rag on the end. Just be careful not to gouge the rotors. Works fine.
csmeance
close
- Join DateFeb 2006
- LocationSpace Coast, FL
Liked:2,190 Times in 1,572 Posts
go to autozone, they should be able to rent you out a piston compressor.
BEAR-AvHistory
close
- Join DateSep 2006
- LocationRaleigh, NC - USA
- Age84
Liked:2,600 Times in 1,581 Posts
Screwdriver.....the Brembo pistons return to the bores with very little effort. Much easier then the rear ones that I use a big "C" clamp on.
AZ Community Team
Bearcat94
AZ Community Team
close
- Join DateMay 2007
- LocationN35°03'16.75", W 080°51'0.9"
Liked:7,771 Times in 4,342 Posts
With the screw-driver, use the old pads as leverage to compress the pistons, then remove the old pads.
