brake caliper piston compressor
Old Jan 28, 2009 | 08:43 PM
mpower635's Avatar
9th Gear
Time for brakes on 2 06 MTs. Is there an aftermarket alternative to this tool or another method of compressing the pistons on the brembo ? If needed where do you buy it ? thanks much sa
Old Jan 28, 2009 | 08:58 PM
nfnsquared's Avatar
Screwdriver with a rag on the end. Just be careful not to gouge the rotors. Works fine.
Old Jan 28, 2009 | 09:15 PM
csmeance's Avatar
go to autozone, they should be able to rent you out a piston compressor.
Old Jan 28, 2009 | 09:21 PM
Timeless's Avatar
I used a screwdriver and used my hands to move the pistons the rest of the way away from the rotor.
Old Jan 28, 2009 | 10:02 PM
BEAR-AvHistory's Avatar
Screwdriver.....the Brembo pistons return to the bores with very little effort. Much easier then the rear ones that I use a big "C" clamp on.
Old Jan 28, 2009 | 10:49 PM
Bearcat94's Avatar
AZ Community Team
With the screw-driver, use the old pads as leverage to compress the pistons, then remove the old pads.
SidhuSaaB
May 30, 2020 12:40 AM
acuratl26
Apr 23, 2020 07:30 PM
Jul 16, 2017 07:33 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
