Braided Brake Lines - Please Help
04-6spTL
Hi All,
Does anyone know of a good steel braided brake line kit for an '04 TL w/ brembos?
I've read tons of threads on good pads/rotors and am probably going with RacingBrake:
Front:
http://www.racingbrake.com/TL_Brembo...p/2108-311.htm
Rear:
http://www.racingbrake.com/ACURA_TL_s/4401.htm
... but I have yet to come across a good brake line kit for my TL. RacingBrake has a kit, but it says "non-brembo" which worries me:
http://www.racingbrake.com/Brake_lin..._p/bl006-t.htm.
Has anyone had any experience with brake lines on their brembo TL????
Your help is much much appreciated.
Front:
Rear:
Originally Posted by cshakari
Hi All,
Front:
Rear:
Front:
Rear:
WDP Director of R & D
Is this just a "show/want" mod or are you thinking of enhanced braking etc.?
If you find good ones, for the cost you will get/feel very little in actual benefits unless you run the car at it's raged edge on a regular basis.
'04 6mt Pearl
Originally Posted by johnny--2k
stainless brake lines will actually help quite a bit in enhancing pedal feel and firmness. The difference is more than you may think.....
Registered but harmless
Received 1,150 Likes
double post...
Originally Posted by Silver Bullet
I was looking for the same. I'm surprised nobody has responded.
Other posters think the stock lines are stainless steel encased in rubber; I haven't checked.
Originally Posted by Will Y.
There was apparently a double-post. For responses and info on the stock Brembo brake lines & options, see https://acurazine.com/forums/showthread.php?t=157207
Many factory lines are - or have other non-steel wrappings that are more than sufficient for the application/braking system. Thats why I made my initial comment.
Used both over the years in several different applications - some "show", some "go". Unless you have the tires, and other max effort/robust brake components,, not to mention race and or rally the car, the bang for buck (or peddle feel) is not there.
As mentioned however, if it's personal taste and a desired mod, who cares whether it has a complete functional reason or not..
Stuck in Kalifornistan
I was told that it would increase the firmness of the pedal. It did an I'm happy with the results.
Former Sponsor
SS Brake lines will firmen the pedal feel. The stock lines are rubber and when the brake fluid heats up the lines expand. The pedal then can get a little mushy. SS brake lines prevent this from happening.
ROTORA makes a nice setup for the TL w/ Brembo's. The lines are $160 shipped.
There are some concerns about running braided brake lines on the street though. It is a known issue that dust can make its way through the steel braids and wear on the Teflon line inside. This can eventually cause fluid leaks. Several brake line manufacturers take measures to prevent this, by putting an extra dust sleeve over the outside of the ss braids. I know both Neupseed (yellow sleeve) and Stoptech (clear sleeve) have covers over the braids, but I don't think either company makes lines for the 3G TL. You can always call them and find out though. Otherwise I would probably skip the SS lines so you don't have to constantly monitor them...
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
