Blue LED converted Climate Bulbs!
Hello Azine, after finishing exams I finally had enough time to spend on doing the conversion because most of my bulbs were out.
I spent literally the whole night, till sunrise in my unheated below freezing garage stripping the interior trying to get to the bulbs
Since it was my first time taking the interior apart, I used:
https://acurazine.com/forums/3g-tl-2004-2008-93/f-051-diy-video-how-remove-center-console-lower-dash-glove-box-733555/
this DIY thread for a guide
Overall the process isn't hard if you have a lot of patience with the detailed stuff..
-Hardest part was the trial and error of getting the 'positive and negative' of the LEDs in correctly.
-Another difficult part was removing the cup holder..the way is it seen in the video, he was able to remove the whole armrest pack but my armrest would not budge one bit.
Led on the left is the T3 bulb that I bought from ebay (30 for 20$, different colors available)
Bulb on the Right is the stock bulb
The bulbs arnt making the whole car blue btw, its from the dome lights (T10 Blue LEDs)
If your planning on doing this I would recommend getting making sure you have extra bulbs, I ended up breaking like 6 trying to get them to fit.
I'm also planning on doing my steering wheel but when trying to remove the T30 torx screws on the steering, my T30 torx screwdrivers handle actually snapped from the pressure (still trying to figure out a way to get the damn things out without having to drill them)
Oh and im also planning on converting the lower bulbs, also trying to figure out how to get to them lol
the lower bulbs on the radio are soldered into the board. So unless you wanna dismantle the radio then I would not recommend it. And I'm interested in seeing how long those ebay bulbs will last. I bought mine from vleds and they didn't last that long.
hopefully they last a decent amount of time, now that iv done this i dont mind redoing it again if they go out, better than the shit acura put in...
So for this did u use 10 bulbs?
Looks super good this is going to have to be my next mod.
Did u do the small ones on the doors as well? Like window button etc
you actually only need 8 for the climate buttons, there is 4 on each side. I would definitely recommend getting a couple extra incase one of the bulbs break while installing
got mine from autolumination.com 1year later still going strong.
Re: the torx screws, get a set of torx bits (not the torx drivers) and use a wratchet and a quarter inch socket to hold the torx bit. that should get them out.
//edit// Also, digging the blue.
Greengecko
09-16-2015 08:19 PM
