Better washer nozzles
I would like to replace the washer nozzles with some that spray whole area. Does an Acura have such nozzles?
The stock 6th gen Accord nozzles squirt in two thin straight streams.
I will make it fit if it doesnt :-) I just need to know which model has the spraying nozzles (if there is any) so I can order those.
Full of water...
I actually like the spray pattern, except it could shoot a little more towards the outside passenger edge. I like because they are meant to be used while moving, unlike most which are designed to work best while sitting. It sucks at first when you forget this and you cover yourself and your seats in fluid while at a light with the sunroof open, but you learn
This is an interesting mod though, keep us updated on what you find.
googled this so far:
RSX - huge mist
2001 VW Passat - fine mist
RL - needs verification
an interesting link: http://www.bowlesfluidics.com/products/index.html
RSX - huge mist
RSX - huge mist
an interesting link: Fluidic Technology by Bowles Fluidics · Bowles Fluidics Corporation
RSX - huge mist
Anyone replace their RL squiters with the "fluidic" kind? Instead of the dual head spray, it's a full panorama of mist?
I'm looking at the Ford Taurus jets as those have a right angle connection 180 degrees opposite of the squirting direction.....
nanos
11-12-2015 08:41 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
