Best type of mobile 1 for a 3g tl?
Don't know about rp. I have had it in my car for almost 2000 miles now. My car feels like shit in the mornings. And for some reason I'm getting more heat soak that i did with Mobil 1 syn. All this happen after the change.
The difference should show itself as the car ages.
Now if you compare it when I went from 5w-20 Mobil One at the second oil change (Amsoil was the 3rd up to present) the engine was noticeably quieter with the thicker Amsoil and also felt like it had a little more kick at full throttle in vtec. It's possible it was in my head because even if it made an impossible 10hp difference, it's pretty much impossible to feel in a 3,500lb car.
Now that I have had the Redline in for nearly 2,000 miles I can say that it still looks like the day I put it in, not that it means much but the Amsoil went dark a little quicker. Could've just been the add pack.
You know what's interesting, the metal stuck to the drain plug had leveled off to next to nothing. Of course it's getting divided up between the magnefine and drainplug magnets but still, very, very little iron shedding.
After the wreck the dealer did a drain and fill with Z1. It went black in 20,000 miles. My shift quality went to crap. When I pulled the drain plug it was fuzzy like it was in the beginning of it's life. Of course that's not absolutely conclusive but it seems to help my argument that the ATD helps with at least the wear metals. I may run this fluid 30K or more with pure ATD again and see if the iron goes back down.
The thing I'm afraid of is that it may not be fluid related. I'm pretty sure it is but there's always that doubt.
I'm going to cut open the Magnefine and replace the factory filter soon. If this trans is anything like the others I've used, the aluminum sheds in large enough particles to be seen with the naked eye. Hopefully there won't be too many surprises.
Yeah the 5w-20 is hard to find. It should be a no-brainer for these retailers, I don't get it. Usually when I do find it, it's the emptiest shelf because everyone is buying it.
The jugs seem to be only 5w-30 at Walmart. I ran it for awhile, but I have found the Autozone deal multiple times now and prefer that. This way I get the M1 filter too and the weight I want.
i really dont get those number for oil and oil fiter... i changed it 5w-20 bc it said it on the cap and the filter mobil m1-104... but is that the best oil i can use my car has 2004, 76000 miles,A/T and i live in miami(hot as hell)
Redline with a Royal Purple filter is an awesome combo.
TLDude876
Dec 28, 2016 03:18 PM
STL TL-S
Sep 23, 2015 08:52 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
