Best ATF?
Old Jul 7, 2012 | 01:27 AM
Coins's Avatar
Best ATF?
I haven't been able to find a definite answer on which ATF are good for the tranny except for Redline Racing ATF. I rather not use that, but that's just me.
Would Redline D4 ATF Be best?
I don't mind ordering online, just what ever is best because I'm about to put the car into the shop for the ATF 3x3 drain/refill.
Sorry if this has been asked multiple times but I failed at searching :P
Old Jul 7, 2012 | 10:15 AM
lucnex's Avatar
Where Did My Garage Go?!!
Get D4 that will work better than Honda's shit fluid if you do not want to use Type F
Old Jul 7, 2012 | 10:30 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
If you're scared/worried, just do 4 quarts Redline Racing with 5 quarts of D4. You won't have a problem...
Old Jul 7, 2012 | 06:49 PM
ChampionFiyah's Avatar
I use nothing but Honda ATF-DW1, and I recommend you do the same. You should change every 30k miles to be safe.
Old Jul 8, 2012 | 01:34 AM
Mrtastygoody's Avatar
Level: Noob
I recommend the Redline Type-F fluid, do the 3x3. It's worth how much the fluid is.
Old Jul 8, 2012 | 11:03 AM
Coins's Avatar
I'm considering this.
But what would be the advantage of having 4 quarts Racing / 5 quarts D4 opposed to all 9 quarts of D4.
I've read a lot of the "The Optimal Percentage of Racing ATF"
Old Jul 8, 2012 | 12:51 PM
lucnex's Avatar
The higher percentage you have of Type-F (up to like 65% I believe as now that is the optimal percantage), the faster your shifts are going to be. Since type F has no Friction Modifiers you can mix the two to get a well blended solution (D4 has FM). This eliminates running too much Type F which some members claimed cause problems for their tranny.
I am almost at 60K and am going to do a 3x3 in about 2 weeks. I plan on using 2 quarts Racing, 2 quarts lightweight, and 5 of D4
Old Jul 8, 2012 | 08:30 PM
pohljm's Avatar
^ the shifts will not be faster. You will just feel them a bit more.
TypeS860
Jan 10, 2026 11:11 AM
vpasla1
Sep 17, 2016 07:24 PM
hashbrown
Sep 29, 2015 12:13 PM
Skirmich
Sep 15, 2015 06:41 PM
mc1114
Sep 11, 2015 05:50 PM
