Baby seats anyone?
Old Jan 6, 2005 | 10:22 PM
viper-tl's Avatar
Baby seats anyone?
Well, as much as I don't like it, our new '05 TL is the "sporty" family sedan. As is such, I will need to put a seat for my 1yr old son in the back. Does anyone have any suggestions for what has worked for them? On the side or in the middle? What about the leather, anybody put anything between the car seat and the leather seats to prevent imprinting? I've heard of using that memory foam but haven't been able to find any yet.
Thanks.
Old Jan 6, 2005 | 10:31 PM
rets's Avatar
Moderator Alumnus
Just FYI from GARAGE...
https://acurazine.com/forums/car-parts-sale-361/wtb-02-03-cl-type-s-exhaust-mufflers-89828/
https://acurazine.com/forums/ramblings-12/ne1-know-when-updated-nav-disk-come-out-83594/
Old Jan 6, 2005 | 10:32 PM
viper-tl's Avatar
Thanks for the links. I did a search but I guess it wasn't thorough enough.
Old Jan 6, 2005 | 10:36 PM
rets's Avatar
Moderator Alumnus
Check further, please. Maybe you have new questions afterwards.
Old Jan 7, 2005 | 11:00 AM
consultauto's Avatar
My TL is also our baby mobile, i recommend using the baby car seat in the middle of the rear seat, also a towel underneath the seat should help prevent distortion in your seat since the middle of the seat is vinyl.
Old Jan 7, 2005 | 11:57 AM
0210322's Avatar
Yap, added TL (kept'91 Integra coupe) since it was hard to put a 1 year old in the seat everytime. I place a thin pillow to protect the botton and the back of the seat. Works ok by the baby seat tends to slide a little. I also have it inthe middle and use driver side access. That way the belt buckes on driver side and it's much easier. Plu the little one gets to see the road better...
Old Jan 7, 2005 | 12:16 PM
AcidHorse's Avatar
Excatly what I did. The towel also helps catch any snacks that fall from the car seat.
Old Jan 7, 2005 | 01:27 PM
PhilB's Avatar
'05 DGP/Parch 5AT Navi
My kids are a bit older and use booster seats. I glued felt on the bottom of the seats to help protect the leather. I had towels under the seats originally but using the felt means there's less stuff to pull out when I have adults riding in the back.
-phil
Old Jan 7, 2005 | 03:59 PM
lakeman's Avatar
My 3 yr old Grandson rides with me sometimes and at first I used the towel trick - actually multiple towels. We ended up buying our own seat so we didn't have to transfer my daughters seat back and forth. I modified the seat by putting sections of "water pipe" foam on all the "edges" that face the leather and taping them on. This has worked great and now that it is permanantly attached to the baby seat, I don't have to deal with the towels.
Lakeman
Old Jan 7, 2005 | 04:02 PM
jcl_cls01's Avatar
I have the need for speed
The car seat I have didn't work too well if it was in the middle (too loose), so I put it on the passesnger side and it was secured nicely in place.
Old Jan 11, 2005 | 01:41 AM
JDOWNLOW's Avatar
7th Gear
As a paramedic who has been to many car accidents, i don't reccomend using anything between the car seat and leather. It prevents the car seat from staying in place if your car is broad-sided. My TL is also my family car, sold my 380hp Ford Lightning for one, and i currently using and only reccomend a britax car seat. If you take care of the bottom of the car seat, keep it from getting scratched or nicked by laying it on it's back instead of it's bottom, it shouldn't damage the leather. I've had my TL for 8 months now and I apply all my weight onto the car seat, proper way to secure it, when strapping it down and there is no damage or "car seat memory" left on the leather. Those of you who don't place your car seat in the middle, or feel like your leather is more important than your child, I hope I don't meet them while i'm at work.
Old Jan 11, 2005 | 02:08 AM
05TL08's Avatar
2005 TL SSM/Quartz
Question
So far it seems nobody has decided to use the LATCH system for the infant car seats.
Before buying my 05TL, I had to put all my weight and try to stabilize the car seat, and then try to strap the seat belt in place, and still it didn't feel very secure. I hated to take it apart and put it back when i needed storage space. All this took me about 15-20 minutes! (no kidding) Anyways, I love the LATCH system, its so easy, now it just takes me 2 minutes, and it is very secure.
I put my car seat in the middle and nothing in between the leather and car seat. I thought about putting a towel but after reading the above post from the paramedic, I think its not worth it.
Old Jan 11, 2005 | 07:12 AM
Black05's Avatar
5th Gear
While I don't necessarily disagree with JDOWNLOW, perhaps he over states his case....First of all, while the middle seat is preferred, those of us with multiples don't have that luxury, although generally they ride in the Odyssey. My local EMT friend evaluated my car seat installation, and said it was the best one of the day, ( a safety fair...seat install evals...etc) and I use rubber backed bathmats......The seats move even less than directly on the leather, and protect the seats as well.
It's just a thought......
Drive safe all.......
Old Jan 11, 2005 | 08:29 AM
SpecialFX's Avatar
For those who are concerned with both their leather and their child go to Babies-R-Us and get a "Seat Saver". It's a formed rubber mat that goes over the seat. There are a couple of versions. Get the two piece one that has a removeable backrest portion. You don't really need it while the little one rides facing the rear. When they're older and ride facing forward you can put the backrest section on and turn the seat around.
The mat is shaped a bit like a tray and catches crumbs and other stuff that may get dropped. It holds the seat securely and will not let it slide around, even more so than the leather. And of course use the LATCH tethers and if possible place the seat in the middle. I also put the belt through the slots. I'm looking for a very small crash helmet to fit a 10-month old. And maybe a padded suit. That little girl is way more important than any car.
Old Jan 11, 2005 | 09:45 AM
viper-tl's Avatar
Thanks for all your comments. I actually went to BabiesRus the other day and picked up the Prince Lionhart car seat protector like SpecialFX mentioned. Unfortunately they only had Gray but that should look ok with the ebony interior. We plan on putting the little one in the middle too....will have to look into the pipe foam that lakeman suggested as added protection.
Didn't think about no longer having quick access to the truck; however, I have a blazer and saturn that could be used if we needed to transport something long.
Old Jan 11, 2005 | 09:49 AM
frainc's Avatar
I agree with you 1,000%. I have my grandsons seat in the middle and no mats or anything else, I don't care about the leather or marks, just that my grandson is safe! I use the LATCH tethers and that seat isn't going anywhere.
My last work on this, hell with the car, always could get another, but not a grandson like the one I have.
Old Jan 11, 2005 | 10:01 AM
viper-tl's Avatar
But I thought the latch posts were only for the outboard seats???
Old Jan 11, 2005 | 02:26 PM
frainc's Avatar
Sorry, that's what kind of car seat his is (he's 4). I was relying to the posts about how folks worry about the leather or marks. Like I posted, I don't care about that just that my grandson is safe.
Old Jan 11, 2005 | 08:40 PM
missmyprelude's Avatar
No, the best place for a child is in the middle, and LATCH will work for the middle just as well. There is actually a tether there for it too. I always used the middle until I had my second.
I, too, use a towel between the car seats and the leather; however, I tighten the car seats so much that they're not going anywhere. Between the LATCH and tethers, the seats barely move at all (front to back, or side to side).
The only problem I have is that I'm somewhat worried that I've compressed the leather seats too much. But, like others have said, my kids are worth way more than anything else, so I don't care all that much.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
