automatic transmisson fluid
i check it like a week ago and it was at um low line.... when should a at change their atf? i currently have around 7500 miles on the car and has any1 had to refill their coolant fluid i did like 2 weeks ago and it was almost empty i was wondering why cause no1 else i know has to refill their coolant lvls... strange
ty for the help guys
![Clap](https://acurazine.com/forums/images/smilies/clap.gif)
Number 3 on the Maintenance Minder tells you to change your transmission fluid. It doesn't tell you when to change it under normal conditions, but under severe conditions it says to change it at 60,000 miles, so normal conditions would give you much more than that, meaning you will probably be able to legally drink in most states by the time you get that many miles on your car and then you can legally drink while you change your tranny fluid.
Shift_faster
Not a Blowhole
http://www.acura-tl.com/forums/showt...ht=RR+Journals
I change every 30K and use the best fluid that is compatible. These trannies are marginal, and it only holds about 7 quarts, total. Change out is 3 quarts. I have done it twice to achieve over an 80% concentration of Amsoil ATF.
SidhuSaaB
05-30-2020 12:40 AM
Joe Avesyan
09-29-2015 03:57 PM
