ATF change question
ATF change question
is were its circled blue were u can put the oil to refill the transmission?
takin care of Business in
Received 4,732 Likes
Cant see the bolts very clearly....but i agree with VIET, it should say ATF on it...the other bolt just looks like a "ground" location....
PS the ATF bolt will be a bishhhh to break loose....i recommend breaking it loose before draining out the fluid....I was stuck once when the bolt wudnt break loose and i had 3 qts drained out....
Bearcat94 (02-19-2012)
^^^ yup, as i mentioned above, its a bitch to break loose....needed a breaker bar and it always sounds like i broke something hahaha....its only the bolt breaking loose....
nanos
11-12-2015 08:41 PM
Skirmich
09-15-2015 06:41 PM
