Aspec Base Lip
Old Jan 30, 2013 | 01:34 AM
DonaldR's Avatar
Aspec Base Lip
Would 07 aspec rear skirt fit on 06 tl? if so with or without mods? explain, same with the front lip
Old Jan 30, 2013 | 06:38 AM
CLtotheTL32's Avatar
The 04-06 and 07-08 BASE rear lips are exactly the same. The Type-S rear lip will require you to cut your base rear bumper.
The front lip is tricky but it has been done before. I'm not sure exactly what has to be done for it to work.
Link: https://acurazine.com/forums/3g-tl-2004-2008-93/unofficial-spec-difference-thread-853331/
The 3G Garage and Google are your friends. Use them.
Old Jan 30, 2013 | 09:31 AM
EvilVirus's Avatar
^ Great write up btw
What is up with all these same questions being ask (intake, apsec, performance chips)? Newbies use the search function either here on the forum or goolge. Goolge easy easier to navigate when looking for threads such as aspec for example.
Go to google, type in question such as: TL aspec differences, will this aspec fit my TL, etc.
Anyway OP you should also clarify which aspec. You said 07 aspec but didnt say if you wanted the base or type-s? You should take your time read the thread CLtotheTL took the time to build for newbies.
Old Jan 30, 2013 | 11:18 AM
Project 04TL's Avatar
in before someone asks what goolge is
Old Jan 30, 2013 | 11:24 AM
What is goolge?
Old Jan 30, 2013 | 11:27 AM
UA6's Avatar
UA6
Only issue you might run into is the color. Some colors from 07 are different from 06.
Jul 16, 2017 07:33 AM
calrow
May 3, 2017 10:21 PM
RL780
Oct 19, 2015 09:46 AM
Nickb257
ILX
30
Oct 11, 2015 02:43 PM
