ASpec Badge Help...
ASpec Badge Help...
I just had the ASpec emblem put on my car (did it the whole kit piecemeal so didn't get the badge till now) and it's on a little crooked.
What's the best way to remove it and re-apply so I can get it straight? Thanks.
So what do I use to re-attach?
Place a piece of electrical or masking tape on the car as a "guide" to achieve a straight and level line for the badge. Apply badge above or below your "guide".
--Remove guide/tape.
Good luck
Thanks. What do I use to re attach it??
Rubbing alcohol won't hurt the paint?
To rebadge it is simple. You can do a few thingsA) 1. Carefully clean the desired location on your car with rubbing alcohol.
2. Scrape off the old sticky tapes on the back of each emblem
3. Heat up the surface where your badge will attach with a blowdryer if the
weather is below 50 degrees outside.
4. Use a double sided tape (can generally get it from Autoparts, pepboys) and
just apply it on the car by making a thin straight line on the car with a wax
pencil or masking tape.
5. Then press the emblem firmly into place and hold it for a few seconds.
B) Take it to a profession that will charge you an arm and a leg for it.
C) Crazy glue it, which I won't recommend.
Hope that helps
