Armrest console padding replacement
Old 04-05-2016, 07:14 PM
mlody's Avatar
my armrest console padding is non existent anymore. instead of replacing the armrest for almost $200, I am wondering if it is possible to remove the armrest cover in order to re-pad it? Has anyone attempted to do this? I appreciate any insights on this.
Thank you
ARMREST, CONSOLE *NH167L* (LEA) (GRAPHITE BLACK) for 2006 Acura TL|83404-SEP-A01ZA
Old 04-05-2016, 08:00 PM
kocyk123's Avatar
Should be an easy task for any upholstery shop. However, I am not sure how much would that cost. Did you try looking at your local junkyard or craigslist for anyone parting out the car?
Old 04-05-2016, 08:12 PM
anx1300c's Avatar
This is what you want. Ten times better than OEM:
Padded armrest - RedlineGoods leather shift boots
Old 04-05-2016, 09:03 PM
sockr1's Avatar
Received 1,159 Likes on 909 Posts
Many of people have done this for less than 10 bucks
https://acurazine.com/forums/problem...cement-640667/
Will Y. (04-06-2016)
Old 04-06-2016, 01:19 AM
Registered but harmless
Will Y.'s Avatar
Received 1,106 Likes on 764 Posts
Yes, and yes; many of us have replaced the padding.
The instructions are in the DIY thread linked in post #4 above.
Old 04-06-2016, 06:12 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
I've replaced mine with 1/2 inch padding that I replaced myself.
Old 04-07-2016, 09:38 PM
LaCostaRacer's Avatar
I bought a new RedLine cover and some of their special padding a couple years ago. Our Pilot has the same problem, but RedLine doesn't sell covers for it so I'll use some new padding and the same leather.
Old 04-08-2016, 06:28 AM
08KBP_VA's Avatar
I just completed this 2 weeks ago easiest and cheapest fix to date if you follow the instructions step by step and I went with 1/2" foam as was easier to work with, viagra for the armrest!
Doing this DIY or getting new are your only options likely any used ones will be suffering the same ailment...
Old 04-08-2016, 12:37 PM
mvp2765's Avatar
We all did the DIY thread.. Very easy to do! No need to spend over $20
Old 04-08-2016, 01:09 PM
TL-GIXXER's Avatar
I think I'll do my armrest tomorrow. I have no plans
Old 04-11-2016, 07:50 PM
mlody's Avatar
This is great info! thank you all. I will attempt this at my earliest opportunity.
sandiego21
1G RDX DIY & FAQ
01-20-2016 08:03 AM
Quick Reply: Armrest console padding replacement
