Anyone paint their Brembos?
I have a WDP 6MT with 19" Anthracite Hiros. I was wondering if anyone painted their front Brembos. I'm considering painting them red and the back calipers red as well. Perhaps even masking out the white "Acura" on the front. The other option is to simply paint the back calipers black to match.
XP, Do you find that the gold color lets brake dust show easily?
I was thinking blue since I have ABP but I found THIS LINK showing the application process and the blue color . I think this shade of blue would look HORRIBLE on a dark ABP car.
For others that are looking for this paint, a quick search on Ebay shows 2 dealers selling the G2 paint kit for $24-$25.
Dealer #1 - $25
Dealer #2 - $24 - HINT - Go directly to the dealer's web-site. These eBay morons are bidding more than what the dealer is selling it for on their site.
Dealer #1 - $25
I just painted my stock front calipers (non-Brembo) black with the DupliColor Caliper paint kit ($15.99 with one can of paint, brush, masking tape, Caliper cleaner aerosol). There is plenty of paint to go around w/ one can, and the finish is semi-gloss. Dried fast, and it was easy to control the paint w/ the brush applicator. I don't know how long it'll hold up, so this is all I can comment on.
92NSX,
Thanks for the info, I would hate it if it started chipping... but I'm glad your experience is that it holds up over time. HOw many coats do people usually put on? I only put on two.
That's the brakes!
I clean the wheels and calipers at the same time with regular car wash and a wheel brush. It doesn't show the brake dust any more or less than the stock color.
I painted the calipers with metallic gold spray paint from Walmart - about $3. I did one wheel at a time using the jack that came with the car.
I masked the area with masking tape and aluminum foil:
It took about two hours on a Saturday morning. The paint dried almost immediately.
Originally Posted by blufox
how do you paint the calipers looks cool i have ABP so if i could find dark blue caliper paint and detailed instructions i will do it
They make a kit designed just for this very purpose. It is made by Duplicolor. It is a very good product and comes with everything you need, paint wise.
They recommend, and so do I, that you put the car on jack stands and remove all wheels while doing job. I don't drive my car (NSX) very often so I was able to put it up, clean everything VERY GOOD and then paint. I can't remember the exact length of time they say to let the coats dry before proceeding again, but it's not very long. The kit is good for at least 2 good coats. I let mine dry for a couple of days before driving again. I think they say to let set for 24 hrs. Using this kit will ensure you never having to do it again.
I know of several guys who track their cars and have no peeling, chipping or any other issues with it.
Best of luck !!!
Originally Posted by Yauser
What are jack stands? How do you jack up the car to get all 4 wheels off? Do the brembos consume more paint than the conventionals? Thanks!
2. Use two sets of stands.
3. I don't see why they would???
I've never seen jack stands used before. Of course I could've assumed what they were, but I wouldn't think that would be stable enough to confidently support a car.
That happened to my friend while she was on call at the hospital. My rims have tuner bolt which require a key, factory locking nuts, and custom locking nuts. Not protection, just a deterent.
You used to see them in NYC when people stole your rims, you'd come back to see your car on stands. In the worse neighborhoods, the car would be up on cinder blocks or sitting straight on the ground.....glad the police have cleaned things up.
Originally Posted by mrsteve
Paint will get dirty after a while and will look like crap since it is hard to clean the caliper. Powdercoating is the way to go.
One last thing, you can still get powerder coated items dirty also. It's not like it puts some type of force field over the part that is resists dirt or anthing.
Spray paint
Yes but powdercoated parts will come clean easier than painted parts.
Good points, +1 rep
EDIT: I got you up to 2 dots
Good points, +1 rep
I clean the calipers everytime I wash the car at the same time I clean the wheels. I don't use strong cleaners- just the car wash solutions and a thin wheel brush that has like a coarse yellow pad (material). The calipers clean up easy and look as good as new after six months. The stainless parts are still shiny (see pic above).
I may have to repaint after a year or two- maybe. It's too early to tell.
XP
Good points, +1 rep
Good points, +1 rep
BTW, thanks for points.
I have seen only 1 other NSX owner with powder coated calipers and they looked very nice. I would like to have it done someday but right now I'm happy with mine as they are.
I will be getting other things on car coated though.
Originally Posted by Xpditor
As I mentioned above, I went the simple route and just spray painted my calipers with metallic gold paint from Walmart. I put two coats on. It dried quickly.
XP
XP
I recall that your spray paint was $3. Many of the caliper paint kits (cleaners included) are $25-30. If you're gonna do all the work of taking off the wheels, putting the car up on stands and masking off the rotors, I would just as soon spend the extra money and do it right the first time.
Time will tell...
I showed you pictures of how I did it. There was no overspray. It was masked well. In my view, I DID do it right the first time.
As I said, it is six months later and there are no signs of deterioration. They still look as good as the day I painted them.
It would be nice if a high price always guaranteed high quality. But, in many instances, it is more an indicator of good packaging and marketing.
Of course, that's your choice.
I however don't think $25-$30 is a high price for buying a product that does exactly what it says it will, as intended, and last much longer than going a cheaper route. You have to remember that you are buying more than just some paint. The kit includes other items to help to do the job.
You have your way, and others have their way. As long as you get the result you are searching for then all is good.
Just a suggestion, use news paper to mask the brakes and everything instead of aluminum foil. The paint will run off the aluminum foil or it may not dry as quickly as news paper so you might end up getting it on your hands or pants and accidentally touch your car with it.
Many ways to skin a cat...
I used foil -following a tip on this forum- as it molds itself around the complicated shape of the brake rotor and can be slipped behind the pads.
I used masking tape for the black rubber and stainless parts. Here is what it looked like with the masking removed:
Will certainly remember that in the futur for other painting projects.
Check this out:
Have a look at this. It might be a good "middle" solution.
Special Caliper Paint
...and note that this is a package of two (2) eleven ounce aerosol cans.
