anyone with Accord Foglight help
does anyone else have this problem. I order a set of 03 accord fogs from ebay. I got it in today and i noticed that there is a gap between the housing and the fog lamp. is it suppost to look like that ?
sand off? what are u supposed to sand dude? u cut the grills but make sure u take measurements 3 times and cut once. I let the grills slightly come in a lil more so i can give the light some kinda support and then I set it in place. I finished up a mark up of a foglight adapter for the 03 fogs to attach to the bumper without a lot of work. next week it should be tested to see how flush it is.
The "OEM" switch from EBAY wont fit the open slot next to VSA/Mirror Controls in the dash. Atleast mine didnt. Dotn hack up your dash to make it fit either, you can get the REAL oem switch from a honda dealer for $20ish.
I don't know how tripn got them to fit without trimming. I went through hell to get it right but that was mostly because I am one of the very few that has the lower grills meshed too. It is easier if you are going to leave the slats. You need to support the center bar through the foglight to get it right, otherwise it will be weak. Took me DAYS to get it right....Guess I am a perfectionist.
The wiring from the Ebay replica lights is garbage. I couldn't figure it out what wire went where, so I made up my own wiring harness and used an HID system with a lighted blue LED switch mounted into the dash. I have my DCC DVD/Nav switch in my blank so mine is directly mounted into the dash next to it. Yep I had to drill, but it was done right, looks discreet and dosen't look out of place at all.
ib18c1, you did fogs too??? DAYM I gotta see this!! Post some pics man!!
quanaman
01-09-2023 07:33 PM
adreano17
09-29-2015 08:48 AM
