any way to make the rear window buttons one touch just like the front windows?
05 WDP TL
hello
i was wondering if there is any way to make the rear window buttons one touch just like the front windows?
it would be much easier to open and close them up by having it "click" and just let it go instead of holding it there
would i need to replace the two rear buttons with the front ones since they "click" or what?
any ideas would be appreciated! thanks
wes
wes
Team SSM
An idea::: The DEI 530T Window Automation System rolls up two windows automatically when you arm your security system. Also controls venting when armed, and can do a full roll-down when disarmed. Senses obstructions and stops window motors immediately. Also automates factory power switches by providing full window travel by tapping the factory window switch.
05 WDP TL
sounds good....do you know if i can just use the wires necessary to use the up/down feature? the factory keyfob can already vent the windows and i did the mod for the auto close when locking the doors twice
just want to be able to tap it once while im driving
thanks
Oderint dum metuant.
This would be wonderful, if anyone knows how to do it. The fronts being one-touch up and down is great, but having to hold the rear buttons is a pain. I know there are some electrical geniuses here...thoughts?
Fightin' Texas Aggie
I avoid opening the rear windows like the plague, what with that horrible vibration that occurs unless you open another front window or the sunroof.
I was thinking the same thing the other day. I use the fob to get the heat out and then I have to hold the rear buttons to the get the windows up before I drive away, and I was thinking, what an absolute pain in the ...If you have one you should have all. Side note, a friend of mine has a Dogde Neon 2002-3 and he has power front windows and roll down rear ones. It is all relative...
Originally Posted by cTLgo
Yes you can, someone has done it on the forum, I can't remember who. My guess is using the same type of relay used on the front doors for the rears...
05 WDP TL
Originally Posted by joshrsmith2411
thats what i have in my tl. and i love it
did you do the wiring yourself? if you did....care to explain? i looked at the instructins and its a bit confusing on which "type" of system the TL uses
and can you just wire it so that you can have the "one touch" feature only and not the others?
thanks
thanks
thanks
If you want this feature of 'one touch' up and down from the drivers door switch only you may get away with doing all the wiring at the drivers kick panel (assuming the TL's windows aren't multi-plexed). If you want this option at each rear door as well as the master control switch wires will need to be ran into each rear door itself.
Since you are only doing the rear door windows, you will only need one module, maybe you already knew that.
I really have no idea about electricial issues, it was aftermarket the shop did it, i love it to death, it sucks when i drive my parents car cause i have to hold all the buttons down, i can vent them, roll them down and up with the remote, also when you lock your doors the windows roll up, i dont think it is as simple as a relay, I have some special thing from dei that does it it hooks up to the viper alarm i have
05 WDP TL
Originally Posted by chusteveb
I've done several of these modules however not on my TL. I'm willing to bet that our TL's would be a 'Type B' and you can check it at the switch if you'd like. I considered doing this mod to my TL and commend you for actually doing it. Since doing my 'windows up with factory fob' mod I've gotten lazy and decided to wait for cooler weather (I even have a few extra modules here in my garage).
i just want this option at the master control switch...no need for the rear doors to have it because i can just control them from the front!
yeh i just thought this would be a cool add on feature along with the window up feature from the keyfob!!
Lets not have any doors so we can just get in and out with out any - anything.... lets just float around ..yea!!! lets get lazy!!!! ALL IN THE WIRES , OPEN UP THE DOOR PANEL AND START MAPPING THOSE WIRES ! GOOD LUCK ! CAN BE DONE.
I added this one-touch to all my windows in my 4-dr Integra and my Grand Cherokee at each location and everyone who rides in those vehicles think my windows are messed up. They'll go and press and hold the button till the window is at the desired position and upon releasing the switch the window continues to go till full open or close. Of course then they're totally baffled and repeat but only in the reverse direction using the exact same procedure of course with the same results. Kinda funny to watch actually.
Anyways, the last car I did for my brothers Evo at only the master control and he's said it's been fine. So I'll probably do it this way from now on (easier install too) even though having it at every location seems cool.
Don't forget to check to make sure the rear windows have the same auto-reverse feature if something gets in the way of closing -- don't want to crush any limbs.
Registered User
05 WDP TL
I'll have to agree with you on that although it would be nice at each rear door since everything else is one-touch open and close at each location including the roof. The draw back I've encountered is that the switches themselves are not designed for one touch operation lacking that click feel when pushed or pulled all the way (for one touch), which is fine except that the operator of that switch doesn't know of this add on feature unless prompted.
hahahha.....funny friends and funny how you sit and watch them!!
yeh it would be nice for each window to have it but i think its gonna be a p-i-t-a to wire for each door and if we do it that way...and if others want to do it i doubt they will go that route...you know what i mean?
well.....i am a no brainer on electrical wiring and what to wire.....so i most likely will ask my stereo installer to see if he wants to do it for me unless someone here is willing to do the mod and do a write up as well???
i really just want the 'one touch' operation on the two rear windows since we already have the window down and window up feature from the keyfob
Originally Posted by rbf351
i was given a loaner 05 neon a few weeks ago for my fiances civic, and same thing, power windows up front and roll down ones in the rear
05 WDP TL
Yeah I agree with you again. I too may want this from the master control only.
are you gonna try this anytime soon?
so you dont think any switches are needed? only one dei 530t module?
thanks
thanks
handsom-hustla
11-13-2015 05:04 PM
