Any Stock 5AT's wanna Dyno in VA?
There is a Dyno Day at Mach V Motorsports in Sterling, VA on March 26th. I am planning to dyno my TL and see if my Intake/Ice box mod is beneficial or not. I would like someone to dyno their STOCK 5AT TL so I can get better base numbers for comparison purposes. I do have some base numbers however these would be a bit more accurate due to possible differences in temps, elevation, and actual dyno. The price is $50 and there are a couple slots still open. Any takers?
~Chris
~Chris
Originally Posted by 1995hoo
Just a thought....that's Easter weekend, may help explain a lack of interest.
Possibly. But, Hey it's on Saturday and there is possibly still a 9AM slot available so plenty of time to do your runs and be gone by 9:45AM.
you should dyno your TL with the stock intake setup and then the icebox to get more accurate results. if you compare to another TL it might not be as accurate because even tho the TL engines are rated at 270 stock it will vary very slighty from car to car just due to the nature of production engines.
I agree with you 100%. However, thats not going to be possible. In order to make my cold air/ice box setup I had to destroy the resonator box. Plus I wouldn't be able to do the swap on such a tight time limit even if I hadn't destroyed the resonator box.
Since I know cars can vary in HP output that's why I wanted an Auto TL to at least get a better rating for comparison purposes. A manual/6 speed will give higher HP/TQ numbers than a 5AT will.
~Chris
~Chris
Yeah they moved. That's the number to their old shop. I guess I should have included the number.
Speak to Dan RE:March 26th Dyno Day
Mach V Motorsports
(703) 435-5000
www.fastwrx.com
Mach V Motorsports
(703) 435-5000
www.fastwrx.com
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
AcuraKidd
09-25-2015 11:18 PM
