Another oil change question...
Old Aug 9, 2011 | 03:25 PM
jus_incredible's Avatar
first i want to say sorry for another oil change question. swear i have tried to research it on this site but cannot get a direct answer. more IMO
2007 base model
is it bad to wait till under 5%?
what type of oil should I buy?
I live in Toronto, CA(I am not taking it to the dealer. i am buying the filter from them then taking it to my mechanic)
How can remove the notice for A1 check light after i do the oil change?
Old Aug 9, 2011 | 03:34 PM
SpiderX1016's Avatar
I don't really follow the MID. I've let it go past 5%. I just change it every 8,000 miles.
Hold the Select/Reset button for 10-15 seconds and press it again to reset it.
Use any 0w-30 or 5w-30 Synthetic and you should be fine or let your mechanic supply you with oil.
It should be covered in your Owners Manual.
Old Aug 9, 2011 | 03:43 PM
Hi speed's Avatar
runnin a little boost
No, letting it go to 0 percent is not a problem. You should be using 5w20 or 5w30 oil.
Buying a filter from the dealer is expensive, but you can do it if you like. A s2000 filter from a Honda dealer will fit and is a little bigger while also being cheaper than the stock filter with no fit issues.
As far as the A1 warning, if you hold the reset button on the dash for 30 seconds while the warning is displayed it should reset it.
Old Aug 9, 2011 | 03:50 PM
why do you suggest let the mechanic supply the oil?
thanks for the reply! much appreciated
Old Aug 9, 2011 | 03:54 PM
dealer quoted me $7. so its not that bad.
SpiderX1016 said 0w-30? any opinions about this....
Old Aug 9, 2011 | 04:25 PM
mau108's Avatar
I'd grab the Bosch Premiums from here (get 75 dollars worth and get free shipping).
http://www.autopartsway.ca/PartDetai.../pagenum1/tabS
For oil your fine to go down to 0% and I'd use a cheap synthetic. My choice as everyone knows is Pennzoil Platinum 5w30 which can be had on sale from 22-26 bucks for 5 qts (4.73 L). I think Canadian Tire is having a sale this week on Quaker State 5w30 Synthetic as well, again a fine oil.
goood plan to take it your mechanic vs Acura/Honda.
Old Aug 9, 2011 | 05:06 PM
MillerTime12oz's Avatar
How many miles do you have since your last oil change? I change mine every 4000 miles or every 6 months. Todays synthetic oils can last for 10,000 to 15,000 miles without breaking down, however, no matter how good your oil and filters are, your oil still gets dirty. Every 4000 miles may be over kill, but i'm still old school when it comes to my oil changes. My car has 85,000 mile on it and I just switch over to 5W20 Valvoline High Milage Synthetic Blend.
Old Aug 9, 2011 | 07:26 PM
Hi speed's Avatar
I wouldn't use a 0w20 oil unless you live in a very cold place. There are no real advantages to going with that thin of a oil. 10w30 is what I use, I feel the added protection out weights any power or gas mileage reduction. 5w20 recommendation from Acura was to get max miles from the car at the expense of wear. Slightly thicker oil helps protect the engine with little increased drag from the thicker oil.
$7 is a good deal for the filter. I like the s2000 filter as another better made and larger capacity alternative, but they are Likely more expensive.
Old Aug 9, 2011 | 08:37 PM
hleapha's Avatar
First off, you live in Canada and you will have this oil in your car this winter. You need a 5w20 oil. Even a 0w20 would work in your environment. As far as oil filter, Purolator Pureones or Bosch are good and reputable. As far as oil goes, it depends on how much you want to spend. Mobil 1 or Mobil 1 EP receive very few complaints. I like Royal Purple, but it is pricey. Redline is going to run you a premium but also could be considered the best especially if you run extended intervals.
Honestly, if you plan on just following the MID, Mobil1 or Pennzoil should serve you well.
Old Aug 9, 2011 | 08:46 PM
RaviNJCLs's Avatar
I tend to get it changed between 0 and 10%. Granted I have only had to do one change since I got the car. I just got it done at the dealership. Got a deal.
I will start doing my own shortly. Typically I use Mobil 1 for oil and Bosch oil filters.
Old Aug 9, 2011 | 10:33 PM
csmeance's Avatar
2007 base model
It depends on how long you should wait. I change my oil as soon as it says service due soon since I use Dino Oil and not synthetic. However if you are using synthetic, going all the way to 0 is no problem. One member here uses such high quality synthetics that he resets the oil % after a change and continues to drive to about 50% and resets it.
the oil indicator does NOT take account synthetic oil or the brand. It's pre-programed for DINO oil and uses an algorithm that takes account RPM, temp, Engine temp, Load, etc. to figure out oil life. According to a number of UOA's, the indicator is pretty good with dino oil.
Get a good oil filter like the flitech Acura ones and a good quality oil like Mobil 1 Synthetic (you can buy a jug of it at wally-world for a good price) and your set!
Old Aug 10, 2011 | 08:35 AM
honestly thank you so much for everyone's response.!
This has helped me so much is making a decision.
I will let you guys know what i decide tomorrow!
Probally gonna get a transmission flush as well since to car is up.
now for the ultimate stupid question...how many litres of oil does the car take? 3.2 cuz of the engine size...
will i regret asking this question LOL
Old Aug 10, 2011 | 08:39 AM
mau108's Avatar
4.73L gets you right to the 2nd dot on my 3.5L should be same sump size for 3.2....Also pre fill the new oil filter (and put some on the gasket as well) before putting it on the car this way it reduces the dry start wear.
Old Aug 10, 2011 | 08:49 AM
nj2pa2nc's Avatar
it's a car-drive it
At 15% and 10%-it will show service due soon
At 5%-it will show service due now
I have gone to past due a few times.
Old Aug 10, 2011 | 09:28 AM
thanks boss
24 Heineken for everyone that responded!
Old Aug 10, 2011 | 10:19 AM
csmeance's Avatar
Don't FLUSH the transmission with any sort of machines! Be sure to open the fill bolt first as they can be a PITA to get off. Once you get that off, simply drain the old fluid out and put in some new stuff though the filler hole. Use a fluid like Redline Racing or Redline D4, or if you wish the acura DW-1 fluid. DO NOT USE HONDA Z-1! Z-1 is a HORRID fluid that will put a death sentence on your car.
4.5 Quarts is what the car uses! It's better to ask than be sorry!
Old Aug 11, 2011 | 09:50 AM
went to the dealership and they said they use the honda atfz-1 (something like that ) for a tranny fluid
ya sure this is horrid?
sorry, im not getting a full tranny flush...just a drain and fill. since the car is up for the oil change...
Old Aug 11, 2011 | 09:52 AM
went to the dealership yesterday and the guy working in the parts area is someone i know! LOL damn im lucky
so dude hooked up a $9 oil filter for free!
cant go wrong! drinks on me!
Old Aug 11, 2011 | 10:04 AM
LoveMyTL-S's Avatar
It's always nice to have a hook-up!!
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
