Amsoil Oil change
Amsoil Oil change
just did an amsoil oil change with mobile 1 extended performance oil filter on my nissan altima and my acura tl-s. i noticed a difference already as far as idle goes amsoil i cant even tell if my car is on i have only drivin around for a couple miles but so far so good....will update
UPDATE: so i notice now that my car with this new oil doesn't seem to warm up as much i notices on my gauge that the oil doesn't get as warm as it use to is that a bad thing?
I would suspect that just the fact that it is newer oil that it would be more efficient in keeping the engine more lubricated thereby decreasing frictional resistance and hence heat.
Did you change viscosities of the oil? I recently made the switch from 5w-20 conventional to Red Line Synthetic 5w-30 and I noticed that under the hood it's much much quieter than it was before. However, upon draining my old oil I found that it was dark as could be and looked like crap.
The sound difference is definitely there though. Valve train noise is not noticeable whatsoever unless the hood is open.
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
