Alternate lift point
Old Nov 15, 2010 | 05:15 AM
soon2b954's Avatar
This past weekend I swapped out my all season for winters. In the process I found that my jack on the rear using the tow hook only went high enough to take off the wheels but nowhere near getting the jack stands under the car. Is there anywhere else I can lift the whole rear end from? There looked to be a spot behind the sway bar? Pictures are always appreciated.
Old Nov 15, 2010 | 06:17 AM
VQPower37's Avatar
in for pics of alternate jack points
Old Nov 15, 2010 | 06:39 AM
Turbonut's Avatar
Depending on the addtional lift needed, place a couple of 2 x 4's or 2 x 6's under the jack, but make them long enough so that the jack doesn't walk off the wood. Some say place a piece of wood in the saddle, but don't like that idea as the hook is free to slide off.
Old Nov 15, 2010 | 06:40 AM
SharksBreath's Avatar
BANNED
as far as i know there are 4 lift points, each one located behind the inside of each tire. they are just plates that fit lift equiptment perfectly. i'd say they are about 5" long. these are the spots that i use whenever i put my car on a lift.
Old Nov 15, 2010 | 07:30 AM
soon2b954's Avatar
I tried putting a 2X10 under the jack but it seemed to move around more than the jack being directly on the floor. When lifting from the hook I tried to make sure I placed part of the cradle with the lip so it would be less likely to jump off.
Old Nov 15, 2010 | 07:36 AM
soon2b954's Avatar
I'm aware of the crimps on the sides but was looking for one spot to lift the entire rear as we have on the front. I did try jacking from the brace in front of the rear sway bar and didn't hear any scary sounds, but then stopped.......
Old Nov 15, 2010 | 07:42 AM
BANNED
^oh...i see what you're trying to do. hopefully someone can chime in who has done this before, i personally have not since i have access to a lift.
someone will come in and explain this for ya tho.
Old Nov 15, 2010 | 07:44 AM
knavinusa's Avatar
I believe you can use the rear tow hook.
Old Nov 15, 2010 | 08:15 AM
Turbonut's Avatar
If you have an area to work, try placing the front on ramps and then lift the rear, or raise the front, place stands under the rails, then lift the rear.
Old Nov 15, 2010 | 08:48 AM
soon2b954's Avatar
I'll give that a go, thx!
So there is no other centre lift point on this car in the rear?
Old Nov 15, 2010 | 12:56 PM
greco9885's Avatar
if you have a low profile jack, you can slide it under the front of the car and lift it from the frame, same with the rear
Old Nov 15, 2010 | 01:40 PM
soon2b954's Avatar
Anyone have a picture of the location in the rear, I think this would help a lot of people out. Thx
Old Nov 15, 2010 | 01:51 PM
greco9885's Avatar
im pretty sure there is, im doing my brakes in a few days so if there isnt a pic by then ill take one, it might be covered by a plastic cover.
Old Nov 15, 2010 | 02:20 PM
CORUPT's Avatar
causing mischief & mayham
I use the tow hook in the back but with a piece of 4x4 on top of my jack. You just have to very careful and go slow. So that it doesnt roll off and fall!!
Old Nov 15, 2010 | 03:04 PM
nfnsquared's Avatar
All you need is a 2" x 12" x 8' board. Cut into 2' lengths. Make a containment border for one 2' section by screwing thin pieces of wood around the edge. Fits perfectly under the tow hook with my cheapass jack:
Old Nov 15, 2010 | 04:56 PM
VQPower37's Avatar
^ great idea
Old Nov 15, 2010 | 06:23 PM
OntheJob's Avatar
Keep'n it clean- Orlando
Id play it safe and invest in a jack with a HIGHER REACH/LIFT capability.
The wood ideas are great fixes, but wood also can splinter and give out, jacks can walk and roll off the wood... just makes me uneasy, and if Im working under the car, I want steel and nothing but solid ground holding about 3,000 pounds off my face. Wood- no thank you. my .02
Old Nov 15, 2010 | 07:58 PM
nfnsquared's Avatar
The jack just lifts the car with no one under it. Jack stands go under the car and the jack lowers the car onto the jack stands before I go under it or work on it....
Old Nov 15, 2010 | 10:05 PM
KN_TL's Avatar
I've got a jack that has a 19 something inch lift and if I only lift the rear using the hook, I can't get it high enough to get stands on the jack points on the side.
If I lift the front from the subframe, put it on jackstands then the rear can be lifted high enough to get stands on the other jack points.
My solution was to build a spacer that goes between the jack and the cup. I made it out of a piece of pipe and stacked squares of lumber. Works fine. As mentioned, I use the jack just to lift it and the stands make sure it stays.
Old Nov 16, 2010 | 02:30 PM
racerock's Avatar
I think it should be mandatory for all cars to have 6 points:
2 - behind front wheels
2 - in front of rear wheels
1 - Center Front
1 - Center Rear (behind pumpkin or rear suspension low enough to use a reasonable jack safely
I'm pretty fortunate to have a very long jack with high lift capacity and highly recommend this to anyone doing above average regular and high level work on a car and plan on doing so for 5 years or more... If you amortize the cost over the life (and extend your life at the same time...) it is worth it.
Jamus22
Jun 11, 2023 10:08 AM
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
mars
Sep 28, 2015 11:03 AM
