Air Filter (not cabin filter) Question
FTW
So I did a search for "filter" and couldn't find an answer so here's my question.
Where are you guys buying your air filter's from?
And what brands are you guys going with?
Thanks!
Thanks!
I just go to the dealership and use the honda/acura air filter. It gets the job done.
FTW
Originally Posted by DrTL05
lose the factory and get a Fujitsu or AEM intake.....never replace the filter again
Thanks!
Thanks!
I just use the OEM air filter. It does the job. My car is still under warranty so I dont want to change to an AEM intake just yet. You can get cheap OEM filters on line. I think Curry Acura has cheap filters or Hondaacura.com also sells them at a reasonable price.
AZ Community Team
Oem
I am using WIX, purchased from rockauto.com. WIX was recommended by various people in this forum. It fits perfectly, as far as I can tell, construction wise is similar to the original filter.
Registered Member
Stock filters on '04 and '05 models are bi-filters. By this I mean that the "bottom" of the filter (the side facing the incoming air stream) is oil-wetted while the side facing the throttle body is a dry element. These filters are pricey and somewhat restrictive, though they work great.
I have been using the Purolator A25585 (think that is the correct number).
Is there any guide, or PDF, that shows how to replace the air filter?
I just finished buying one from Acura (OEM) for 18 dollars (canadian)
I just need to figure out how to do it now....
I use a k&n filter. I don't really care about the performance (I didn't notice any difference) but I like the fact that I won't have to buy an air filter ever again.
I used one on my mustang for almost 100k miles and it was fine.
I bought on-line. Don't remember which website.
Lube the screws!
Just replaced mine last week. Two of the screws were almost frozen in place, and I was afraid I would strip the heads trying to remove them. Ended up using a socket driver, extension bar, and a vise grip for leverage. I shot all four and their receivers with WD-40 before reassembling. Changing the intake air filter is easy compared to the cabin air filter, but both jobs are a lot more difficult than they need to be.
