Air filter
Air filter
Hey everyone-
I'm getting a musty smell in my vents when I turn on the fan/ac. I was thinking that a new air filter might correct the problem. I have no idea where its at though. I have a '05 TL. Do you think that would help with the musty smell?
Thank you for any help!
It's behind the glove box, which needs to be removed to access the filter:
https://acurazine.com/forums/showthr...t=remove+glove
Also do a search on the musty odor to see if the various A/C that are recommended might help. I've not had any odor problems from ours.
Turn off your A/C a few miles before reaching your destination and make sure your fan is set to its highest speed. This will help to dry out the evaporator which is where the odor originates. Also, keep the use of the recirculate feature to a minimum.. outside air helps to keep the humidity from building up in the cabin which increases condensation around the evaporator.
Originally Posted by stensj34
Thanks for the help. Are there 2 different air filters in a '05 TL? I've found the cabin air filter and just an air filter. Anyone know this?
So is it possible to replace the engine air filter, or do most people just replace the cabin air filter?
Is the engine air filter easy to get too? Do you replace both yourself? thanks for the help, I really appreciate it
Actually, the cagin air filter replacement is made difficult because of a very poor design on Acura's part. You'll see what I mean by this when you do your first change.
Given the air quality here in NY, I change the engine air filter every other oil change.
The cabin filter every 2 years with the ATP Part # HA5 from www.rockauto.com, $15.80.
The filter media is treated with charcoal to reduce odors. Works well.
Originally Posted by jmsjames
Does anyone know where the engine intake air filter is and how to remove/check it?
To remove it, you will need either a long philips screwdriver or better, a nutdriver with a long extension. Just completely loosen the 4 screws which secure the housing top at each corner, then carefully move the top up and out of the way (be careful because the housing top is secured to the ribbed throttle body coupling). The filter is inside the housing and is of a dual filtering design, i.e. the bottom is oil-wetted and the top is a dry paper element. When replacing with an OEM filter, you must install it in the same position.
Really, this is maybe a 5 to 10 minute job.
I bought a STP air filter for the engine, but was in a pinch. I couldn't find any others. Probably not the best filter. What type do you use Southernboy?
Anyone have a take on this?
Am I confused?
Originally Posted by sandynmike
Doesn't the A/C evaporator remove humidity from the air by condensing on it and draining off the water, like a cold drink in humid weather? So on recirc, the AC keeps drying the interior air?
Am I confused?
Am I confused?
The reason recirculate will increase humidty in the cabin is easy to prove in the cooler months. Try using it on a cool fall morning and watch the interior humidty develop. It's caused by people in the cabin breathing and giving off body heat. Drawing in air from the outside virtually eliminates this.
I use the factory OEM Acura filter in both my '04 manual and my '05 automatic. I am inclined to try the Purolator unit or STP (if I can find it). Not because of price so much but more along the lines of maybe a better flow???
My best buddy from high school owned an auto parts store for 27 years and wouldn't put ANYTHING Purolator in his car, especially their oil filters.
If you have mildew growin on your evaporator, you have a drainage problem, most likely a plugged drain hose.
I use recirc+A/C whenever I step into the car. Been doing that for 25+ years, including 2 TLs. Never had an issue with mildew. Only had one car with mildew, but I found the drain plug, cleaned it, and about half-a-cup (seemed like it) drained out when I fiddled with the drain hose.
Typically you get freeze-up on the evaporator when you have poor air-circulation. (Like if you close all your vents except for 1 or two.
Originally Posted by avs007
You sure you aren't confusing it with Fram? I thought Puralator oil filters were actually among the best in it's price range.
Regardless, I wouldn't use the orange fram oil filters either.
Originally Posted by THTL
DMZ, how come your friend don't stock Puralator filter? Is it that bad or as bad as fram. thanks.
Asi stated in a previous post, if you're looking for a cabin filter, get the ATP Part # HA5 from www.rockauto.com. It's impregnated with charcoal to reduce odors, works very well.
As I stated in a previous post, if you're looking for a cabin filter, get the ATP-5 from www.rockauto.com
Not unless it's zero humidity outside. Even if you have it running on outside air, you will still get significant condensation on the evaporator.
It has been mentioned to keep the drain tubes free running and this is absolutely true. When I use my A/C, I have found the Auto setting to work excellently and I just let it do its thing. Yes, this does run the system on recirculate, but only until the interior temperature as reached your setting. Then it reverts to outside air.. and it does a remarkable job of it in my TL. Shortly before I arrive at my destination (say 5 minutes or perhaps maybe 3 miles), I turn the A/C off and go to maximum fan speed through the vents to start the drying process. This has seemed to help a good deal and I have never had the moldy musty smell in my cars' cabins.
He closed the store 2 years ago. To this day, he swears by never using Purolator, Group7, nor the orange Fram oil filters.
I see there are some negative comments about the Purolator air filters (engine and cabin). These are currently in both of my TLs. Do you think this was a bad move? I'm far more concerned about the engine filter and any chance contaminants might make it into the engine. I know the Purolator is quite a bit better than a K&N for this, but I worry maybe not as good as others. The factory OEM filter is definitely "hi-tech" in that it is a two-part unit.
Opinions/Comments?
Have to ask this.
Opinions/Comments?
Opinions/Comments?
Originally Posted by Repecat
...I wouldn't let a K&N air filter near my car.
I cleaned and re-oiled the K&N immediately filter after the last engine oil change only because I had the airbox off to also change the tranny fluid. I'm anxious to see if there's any change in air filter performance in my next UOA at around 63K miles (in a few months.)
Low Silicon readings in UOAs are the prime indicator of a well-functioning air filtration system.
rcs86
Aug 2, 2016 06:52 PM
