Accord Fog Lights with Projector retro
#161
Former Sponsor
Not really a DIY. You need a powerful blade, cut the back and mount the projector. You have to make sure the projector is facing the right way (There is a top and a bottom), its even (cut off line), not facing too high or too low. A lot of trial and error, patients and just very time consuming.
#162
#164
UA7 6MT
Just ordered a set of these from Retrofit Source and had a question about which wiring harness to ask for as I have an 06 TL. It didn't natively come with fogs wired in thus I am not sure which harness to use as I intend to mount these with seperate switch. The 07-08's utilize the 9006 Low Beam harness if I'm not mistaken.
Would that be the safest bet for me for my intended purpose?
#166
Here are the pics per request:
ONLY BLAZER FOGS ON * They look a little bit better than in the picture, it's very hard to capture the actual light*
HEADLIGHTS AND BLAZERS
HEADLIGHTS, BLAZERS AND UPPER FOGS * My Upper fogs are most likely a lot stronger than everyone elses.*
also your pics of JUST the fogs on at night looks crazy...i feel like mine only points towards mostly the sides and i dont really get output towards the front.
I will take pics and post it up later.
#167
No i did not need to remove the passenger side horn. BUT it was a tight fit. I believe AckTL said he had to. So if your's are aims more to the side then the other side of the projector will most likely be hitting the horns. If you haven't sealed them yet you should try straightening them out.
Before I finished mine I did many test fits by just taping everything together to make sure it fit correctly. I'll wait for your pictures to comment more.
#172
Land of 10,000 lakes
Not sure what the harness is on the accord fogs, which I'm assuming you're using since you have an '04.
http://www.theretrofitsource.com/index.php?cPath=28
#178
InFaMouSLink
10-27-2015 06:51 PM
oyayjoe
09-12-2015 04:40 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
