Ac Stink
Old Apr 15, 2008 | 05:13 PM
kevinacura's Avatar
Ac Stink
Hi, My TL is stink when I turn on AC. What can i do to get rid of that bad smell
by the way, my TL has 10k miles on it.
Old Apr 15, 2008 | 05:19 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
When you use your A/C, turn it off at least 1 or 2 minutes before you plan on turning your engine off. After you turn the A/C off, use the ventilation system with natural (unrecirculated) air until you reach your destination, and then turn it off, before you turn your engine off. Since your car stinks, you have to change the cabin filter. Also, spraying some Lysol (or other products) into your A/C main vent, which is below your winshield wipers under the hood, and into the vents inside the cabin, will help to neutralize the mildew which has been built up by your A/C evaporator.
I've been through this myself with the wife's car, as she always leaves her car A/C on. But if you want your A/C to steadily blow "clean" air, this is a no-no.
Old Apr 15, 2008 | 05:50 PM
erick3's Avatar
yeah...i have this too...thanks for the info prince!
Old Apr 15, 2008 | 08:28 PM
Your welcome, Erick.
Old Apr 16, 2008 | 06:14 AM
SouthernBoy's Avatar
Registered Member
Absolutely correct. Use the recirculate feature at a minimum to avoid condensation buildup. And like prince said, turn the system off several miles before you get to your destination and run your fan on high to remove some of the moisture from the evaporator coil.
Old Apr 16, 2008 | 09:17 AM
RJANACONDA's Avatar
Registered TL Lover
Dont forget to change that cabin air filter!
its cheap and easy and there is at least one DIY here to show you how
Although 10 k may be a little early....
Old Apr 16, 2008 | 11:06 AM
Registered Member
Old Apr 16, 2008 | 11:48 AM
RJANACONDA's Avatar
Registered TL Lover
From the 3G garage...
F-019: Musty smell from A/C
https://acurazine.com/forums/showthread.php?t=87078
https://acurazine.com/forums/audio-video-electronics-navigation-22/diy-crossovers-filters-78151/
https://acurazine.com/forums/showthread.php?t=103735
Old Apr 16, 2008 | 03:07 PM
kevinacura's Avatar
Can I ask if this AC stink problem cover under guarantee?
Old Apr 16, 2008 | 06:10 PM
Registered Member
I can't imagine it is. It's pretty common with Honda products.
wstevens
Dating & Relationships
30
May 22, 2005 09:01 PM
