ABS sensor difference between Type-S and Base?
Old Oct 12, 2021 | 03:41 PM
Samuel Cartledge's Avatar
7th Gear
Is there a difference between a front ABS wheel speed sensor for a Manual/Type-S (with Brembo calipers) vs a base model with normal calipers? If there is a difference, does it matter? Are the parts interchangeable?
Old Oct 12, 2021 | 03:50 PM
Take the OEM parts vendor website below, look up the ABS wheel sensor (under Chassis; Knuckle) for the year TL you have in mind and refer to the 'Vehicle Fitments' area at the bottom. The answer is there.
Discounted Genuine Acura Parts Online | Delray Acura Parts (acuraoemparts.com)
Old Oct 13, 2021 | 03:22 PM
7th Gear
The website does not differentiate between manual transmission and automatic transmission, which have different knuckles. There's also a difference between it technically not fitting and in practice if it will actually work. I was looking to see if anyone actually KNEW.
Old Oct 13, 2021 | 03:40 PM
peter6's Avatar
There are two versions for each knuckle but only one version for each sensor, so I'm betting sensors are the same.
https://www.oemacuraparts.com/v-2006...assis--knuckle
Scott Salt
Feb 25, 2022 03:18 AM
Jose Aguilar
Nov 11, 2016 12:42 PM
Adam722
May 2, 2013 02:59 PM
A.Juggalo
Sep 9, 2011 07:24 PM
JTso
Nov 22, 2006 11:25 AM
