Тормоза
Old May 4, 2021 | 03:44 AM
ROKET's Avatar
Тормоза
Hello everyone. How much do you need brake fluid for a complete replacement? (TL-2006)
Old May 4, 2021 | 06:31 AM
I have used 3 12oz containers of Honda brake fluid on my CL-S6. The key is to make sure the lines flush clear. To maximize this try and remove as much of the old discolored reservoir fluid with some kind of suction device first. Pour new fluid in. Bleed as appropriate until you notice clear fluid, repeat. Making sure to monitor the reservoir level so it does not run dry.
Old May 4, 2021 | 07:38 PM
csmeance's Avatar
I used close to 1 Liter doing the brakes on an Automatic 3.2L TL. I used 1.5L doing the TL with the larger brembo brakes (manual / standard transmission / Type-S). It takes a lot since the brake system has the ABS pump all the way on the passenger front of engine.
dcmodels
1G RDX DIY & FAQ
Aug 4, 2025 03:49 PM
dcmodels
1G RDX DIY & FAQ
Oct 27, 2014 11:47 PM
dcmodels
1G RDX DIY & FAQ
May 29, 2013 11:16 AM
dcmodels
1G RDX DIY & FAQ
Jun 13, 2012 12:29 AM
