6MT Owners- Annoying Clutch pedal Squeal
B A N N E D
Hey guys i got 04 TL 6MT it has 60k on it, so its out of warranty, and i have the annoying clutch pedal squeal, its really annoying me, can i go to an independent shop to get it fixed ? any ideas will be greatly appreciated
Mike's Silver Bullet
Continuous squeal while the pedal is depressed, or squeak while the pedal is moving?
Continuous squeal could be throwout bearing - shop, could use an independent; note that installing the clutch and pressure plate requires a special, specifc tool.
For the squeak, you could lube the linkage yourself.
B A N N E D
francois
Francois
"Advance"
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Look at this thread https://acurazine.com/forums/ramblings-12/ftp-help-129314/
Post Number 18, I had the same problem, brang my baby to the dealer, they greased the clutch, tested it, noise was gone, if the noise still occurs, replace the MAster!!!
Thats it! good luck!
J Bill
I actually have my '04 in the dealer today to look at this problem once again. I took it in about 2 months ago and based on my research here at Acurazine told them I think the Master Cylinder needs to be replaced. Unfortunately they don't give much credit to our owner's group here and only did a lube job on the part. One week later the clicking sound was back. Hopefully they will replace a part today and get it fixed. I'll let you know.
This is a common problem with the TSX.
https://acurazine.com/forums/showthread.php?t=21284
https://acurazine.com/forums/showthread.php?t=33489
http://www.driveaccord.net/forums/at...tachmentid=488
I had to have the master clutch cylinder replaced twice in less than 24K miles on my 2004 TSX for the same issue. The Accord/TSX/TL uses the same part.
http://www.acuraoemparts.com/delray/...1=&inputstate=
Last time I took my TSX in, I was told that Acura was aware of the issue, and was redesigning the part.
The part alone is $125 and it looks like is should take no more than a hour of labor to swap it out.
Good luck
Good luck
B A N N E D
Originally Posted by Kostyan
hey lil ALex is that you? Congrats on your new ride! What hpnd to CL-S?
Yea its me, whats going on ? i sold the CL-S...
B A N N E D
Good luck
Good luck
Thanks man, I'll look into that...
I was actually referring to the clicking... not sure about the squeal. Regardless, it is annoying enough that it was a factor I considered when getting an auto rather than a manual in my TL.
uh yea please dont use WD40 its a degreaser......... use a silcone grease spray..... take off the cover thats blocking the linkage from being seen and spray it up... make sure u cover the wiring when u do that so nothing shorts if that doesnt work im sure some how acura or whoever u bought it from would honor some kind of warranty unless it was a private sale. and the clicking would go away too
J Bill
SidhuSaaB
05-30-2020 12:40 AM
