6 Spd TL '04-'08
Just curious by aftermarket you mean OE replacement not OEM right? If anything I would see if Oreillys might carry it. If not you can try ordering off the internet.
Honda Accord 06 V6 6spd
Part # 44306-SDP-A00
Acura TL 04 6Spd
Part # 44306-SEP-A02
they r different
Yes, but it is actually a common swap to put the TL axels in to the AV6, I have put the two side by side with no "visible" or "mesurable" differences.
Also the Advance ones are NEW from GP Sorenson for $69.99 ea.
Interesting... that's the first Honda part I've seen more expensive than it's Acura counterpart
^^But either way thanks for sharing that piece of info!
All About Trance
This link https://acurazine.com/forums/3g-tl-problems-fixes-114/new-axle-needed-751160/ also discusses drive shaft axel as well. I had gotten the GSP one from Advance Auto Parts and the serial number for the auto and manual are both the same. I had mine replaced last weekend and so far so good. Now the right side is starting to do the clicking sound upon cold starts. However, I cannot find one for the right from AAP.
This link https://acurazine.com/forums/showthread.php?t=751160 also discusses drive shaft axel as well. I had gotten the GSP one from Advance Auto Parts and the serial number for the auto and manual are both the same. I had mine replaced last weekend and so far so good. Now the right side is starting to do the clicking sound upon cold starts. However, I cannot find one for the right from AAP.
We never got to install it tho
Sometimes both axles are really close in length but you can barely tell. This happens sometimes where you might have gotten the wrong side which throws off the measurement a bit. I have seen that happen a few times.
All About Trance
Yep, I have a 6spd. And no, no issue as I had stated previously.
Does yours do the clicking only when cold? Cuz i have the same thing. On cold it makes horrible clicks, but after it warms up its way less.
Fearless DIY Guy
...the only difference here is that an axle is not commonly conceived as having a quality aftermarket alternative.
My axles are fine, but I will gladly use them for the TL when/if the time comes. There already exist a bevy of OE components I cannot wait to get the hell off my car, and I for one am not worried about fitment from tried and true suppliers such as this.
All About Trance
Yep, only on cold does the right side do the same as you had described. It's not quite as loud as the left which seems to be the only side that people seem to have the most problems with.
All About Trance
The reason why the part number is the same for AT and MT for the driver side is that they're identical. However, after recently getting my passenger side rebuilt, it is a little different. The end that connects to the wheel is a bit larger than on the driver's side. That's why we can't find it in the auto parts store for MT.
"Let's Do This"
If your still looking for the axle let me know bc i got mine from a dude in Hempstead, I have a manual too! perfect fit and its a rebuild....the guy knows axles like the back of his hand
Thought i should revive this thread, so pretty much 1 year ago i tried an aftermarket axle, said to myself ill see how the quality is....Well to make a long story im in need of another one. Getting a vibration while accelerating and i know its that aftermarket axle..
Now im lookin into gettin an OEM or raxles axles.
Oemacuraparts has them for 197$ shipped to my door... Any1 knows any other site that has them cheaper? If so plz post up thnx, Curry acura no longer gives there discount altho ill try callin them see wat they say
BoricuaTL
04-08-2016 01:08 PM
DerrickW
11-15-2015 05:52 PM
DerrickW
20
09-27-2015 02:45 PM
2005, 44306sdda00, 44306sdpa00, 44306sepa02, acura, advance, auto, axle, fit, half, parts, shaft, specification, tl
