6 spd manual trans flush
Old Jan 17, 2010 | 07:14 PM
vovka2007's Avatar
Is it required to change the oil in 2004 manual trans? I know its required for auto's, but heard otherwise for manual. Any ideas?
2004 TL 136k miles. Shifts smoothly considering the miles.
Old Jan 17, 2010 | 07:30 PM
AckTL05's Avatar
Former Sponsor
It is recommended at 60k. I did mine at 50, just because it shifts smoothly doesn't mean it doesn't need to be changed. Some do the 3(x)3 method but thats a waist of oil. I would drain it and pore the recommended amount back in, you don't want to over flow. I used about 2 and 3/4 quarts (2 and about 700ml which is posted on the side of the container). The drain can be found in the service manual or here where I found it. I cannot tell you exactly where it is but its under the driver side front, you need to remove the plastic under garments. Its as simple as an oil change, make sure you get manual tranny fluid from ACURA or some use GM synchromesh fluid. Since you have no problems, I would use the regular ACURA fluid.
Old Jan 17, 2010 | 08:38 PM
I hate cars's Avatar
You don't flush a manual. The vast majority of the fluid comes out in a simple drain and refill. On an automatic half or more of the fluid is trapped in the torque convertor so only half comes out when you drain the sump which is the reason behind flushes and 3X3 fills.
Old Jan 17, 2010 | 10:27 PM
subinf's Avatar
One on the right for me
Yes. I do it every couple years.
Old Jan 18, 2010 | 03:36 AM
vovka2007's Avatar
Could somebody tell me where the plugs are for draining and refilling?
Old Jan 18, 2010 | 04:34 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
Yeah every couple of years, or once a year if your anal about it. Im using 2 quarts of Royal Purple Synchromax an .5 quarts of the Honda stuff.
Old Jan 18, 2010 | 04:43 AM
SouthernBoy's Avatar
Registered Member
The drain plug is located on the bottom of the transaxle case and is the same size as the crankcase plug. The fill plug is located on the top of the case and is under the ribbed throttle body coupling. It is rather large and has a female 3/8" ratchet depression.
Do this with your transmission level and use a torque wrench. The fill plug is going to be hard to remove if this is the first drain and fill. Refill with 2.3 quarts (that's 2 quarts, 10 ounces - U.S.).
Old Jan 18, 2010 | 10:58 AM
subinf's Avatar
Also open up the check plug so you know when to stop filling.
Old Jan 18, 2010 | 11:01 AM
subinf's Avatar
The drain plug? It uses a ratchet, not a 17mm wrench
Old Jan 18, 2010 | 11:09 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
There should be a DIY on this in the 3G Garage.
For you, OP, I would DEFINITELY do the 3x3 drain/fill. SB is right, each "fill" should be 2.3 quarts after a drain. So you'd need 7 quarts total.
FWIW, I do mine every 30k, 3x3.
Old Jan 18, 2010 | 11:11 AM
subinf's Avatar
Why drain/fill the manual transmission 3x. That is a lot of money on fluids when it is unnecessary. I can understand doing it for the auto if you don't have a machine to flush the fluid, but a waste for the manual.
Old Jan 18, 2010 | 11:18 AM
In this case, the OP isn't sure whether it's ever been done on his car which has 136k on it.
As for me, yes, it is a lot of money on the fluid, since I use the GMSMTF-FM. But, I'm unwilling to get the 3rd gear TSB done, and this ENSURES proper shifting, and peace of mind for me.
Old Jan 18, 2010 | 06:23 PM
vovka2007's Avatar
Does synchromesh really help that much? also what if i mix it with the regular stuff.
Old Jan 18, 2010 | 06:26 PM
subinf's Avatar
I wouldn't mix it with the Acura fluid, just use GM
Old Jan 18, 2010 | 06:30 PM
vvv
+1.
The Acura fluid, even the reformulated one=:thumbsdow
Old Jan 18, 2010 | 06:55 PM
KN_TL's Avatar
I had the 3rd gear issue and GMSMFM made it go away immediately. Like others had said, don't mix. Not sure why you'd consider it anyway.
Here is a thread with some pics of the actual plugs and the service manual by our resident 6MT expert SouthernBoy.
https://acurazine.com/forums/showthr...t+fluid+change
Old Jan 18, 2010 | 08:20 PM
AckTL05's Avatar
Former Sponsor
It all comes out in a manual transmission anyway, no need for 3x3. Getting on this asap would be a good choice though.
Old Jan 18, 2010 | 08:31 PM
mmade22's Avatar
200,000 mile club
No need to flush a manual transmission!!!! PERIOD! No torque converter, no other things that hold transmission fluid in. Drain and refill with the GM Syncromesh and call it a day! End of story. Unless you like waisting money during these great times of the economy. Send payment to.......
Old Jan 18, 2010 | 08:42 PM
JwongTLS's Avatar
Just wanted to add: When u drain out all the fluids, shift the gears around; there are still some fluid in the gears.
Old Jan 19, 2010 | 04:08 AM
vovka2007's Avatar
Thanks for the info. Is there a difference between GMSMF Friction modified and plain?
Old Jan 19, 2010 | 07:34 AM
Registered Member
The part number for the GMSFM fluid is 12377916. This is what you want. And it ain't cheap - but it is worth it.
Old Jan 19, 2010 | 07:35 AM
Registered Member
Thanks for the nice remark, but I can assure you... I'm not a manual transmission expert.
Old Jan 19, 2010 | 07:57 AM
Registered Member
If one does this, I would strongly recommend care when putting the check plug back in. Use a torque wrench with this plug. It is only supposed to be torqued to 8.7 lb/ft. A few of the members have not used a torque wrench and have tightened this bolt too much, causing the head to completely separate. Not a good thing.
I would recommend just adding 2 quarts, 10 ounces and leaving the check plug in place. Too easy to cause yourself heartache with this one. Not one of Honda's better ideas.
Old Jan 19, 2010 | 11:17 AM
Yonkers914's Avatar
04Tl
That's what i did 2 quarts and ten ounces of the Acura stuff and running perfect so far no need to use the check plug.!!
Old Jan 19, 2010 | 11:40 AM
TlYungGun9's Avatar
I just called my local chevy dealer and they said it was 18 bucks a quart. Is it really that expensive???
Old Jan 19, 2010 | 11:41 AM
subinf's Avatar
I've never had an issue with putting the plug back in place. You don't want to overfill the transmission as you can cause a fluid leak if there is too much fluid in there. Safer to just ensure that you have the appropriate amount.
Old Jan 19, 2010 | 01:09 PM
Registered Member
The check plug is a good approach, as is the recommended refill quantity. I recommend against removing the check plug for the reason I gave. I can imagine the sudden sinking feeling in the pit of one's stomach as they suddenly wrench off the head of that little bolt. The 8,7 lb/ft of torque doesn't leave a lot of wiggle room for error.
Old Jan 19, 2010 | 01:11 PM
subinf's Avatar
Peace of mind for me. Dealer overfilled the tranny upon delivery of the car or didn't ensure it was at the appropriate level...same thing in my eyes. I had some issues with the fluid leaking. They tried to blame me for their mistake. Makes it easier for me to know when the level is correct when I see it start to dribble out of the check hole.
Old Jan 19, 2010 | 01:56 PM
Call around and haggle, I think list price is like $11. I got my RP synchromax for ~the same $10-11 a quart. The GM FM stuff does feel better then the non FM version and it also feels the thickest of them all, felt pretty good, gives you a solid feeling. Went to try RP for kicks and its alright, feels thinner but not in a bad way.
Old Jan 19, 2010 | 02:05 PM
subinf's Avatar
I think I paid 13 at the dealer in CA.
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
LeVeL
Oct 18, 2015 04:19 PM
