5AT vs. 6MT handling
#81
Originally Posted by brahtw8
While the original post may have been somewhat inartfully worded on the subject of gear ratio, the above numbers [gear ratios only, auto vs. manual] don't really tell the story until you do the math to figure out the effective gear ratio in each particular gear.
In other words, in 1st gear you have an effective gear ratio equal to 3.933:1 x 3.285:1.
BTW, 3.285:1 is higher than 4.428:1. Remember the number is the expression of a ratio. A higher number actually means a lower gear ratio.
The REAL "story" MUST INCLUDE THE TORQUE CONVERTER (in an automatic) if you wish to compare TOTAL torque multiplication of an automatic car vs a manual car.
#82
"...but apparently he could not let that stand, so he went and found an article about drag racing and automatic transmissions with high-stall torque lockup converters, from which he took an isolated paragraph and used it to try to insinuate that I had somehow provided an incomplete answer.
The entire article is reprinted below, and does not make the conclusion that he has implied, which is that you need to multiply the effective gear ratio by a factor of 1.5 to 2.2 for an automatic transmission because of the effect of the torque converter. That is of course simply ridiculous and easily disproven by simply comparing the effective gear ratios of the TL 6MT and 5AT, which do not support a disparity on the order of 1.5 to 2.2 times."
Go ahead and compare them for us, being sure to INCLUDE THE TORQUE CONVERTER'S MULTIPLICATION FACTOR FOR THE AUTOMATIC CAR!
You said that you could "easily disprove [my] claim by simply comparing the EFFECTIVE ratios."
What are they?
You also seem to imply that the phenomenon is limited to "high speed" torque converters. It is NOT. ALL TORQUE CONVERTERS MULTIPLEY TORQUE - hence the name - TORQUE CONVERTER!
What are they?
#83
Originally Posted by harddrivin1le
THAT doesn't tell "the story," either, because it NEGLECTS THE TORQUE CONVERTER.
#84
I was talking about gear ratios. The torque converter does not change the gear ratios. It may result in the application of more torque to the wheels, and gives a result that is essentially the same as putting in a lower, variable gear ratio, but the gear ratios are static and do not change.
http://www.islandnet.com/~victrans/Multiplication.html
"By torque multiplication, we mean that there is more torque on the turbine shaft than the engine is putting out because the vortex fluid is accelerated more than once. Torque multiplication is obtained at the sacrifice of turbine rotation. Actually, it's no different from the mechanical advantage which your get from gearing down. You gain torque by sacrificing motion.
Torque multiplication takes place anytime the turbine is turning at less than 9/10 impeller speed. At full stall, the stock AOD converter produces about 1.85-to-1 torque multiplication. As the turbine speed increases in relation to the impeller, torque multiplication decreases."[/QUOTE]
#85
Andrenaline Junkie
You were a little slow on that edit. Too bad I quoted you first.
See how you tried to change 'claim' to 'support the notion'.
That is pathetic.
That is pathetic.
#86
Originally Posted by Swat Dude
This is Harddrivin's M.O. Check out the Chrysler post. He argues incessantly about something he is having a hard time understanding and then morph's into understanding and tries to act like he knew it all along. I think he should change his name to Backpeddling1LE.
#87
HD, in your world, are you EVER wrong?
Oh, and thanks for reposting over and over gain. I wasn't able to read it the first time, or the second, or the third. Man.
#88
Andrenaline Junkie
#90
What are they?
What are they?
Here is your math for 1st gear only (and I should check it first, but I'll assume you know how to use a calculator)
Auto: 2.563 X 4.428 = 11.35:1
Manual: 3.933 * 3.285 = 12.9:1
Now multiply the Auto's effective ratio by a factor of 2, to make it simple.
You are saying the automatic has an effective gear ratio of 22.7:1 in first gear? Do you have any idea what that would mean in terms of the maximum road speed for the car in 1st gear, or its ability to accelerate in 1st gear?
The manual first gear basically runs from zero to around 35 MPH. If the automatic was able to apply that same powerband from zero to 17 MPH, which is what you are saying, it would blow the doors off of the manual, at least until hit redline in 5th at 75 MPH.
#91
Well, Norse. I DO have the chance to do it over again. I have a 5AT Navi on order but I can switch to a 6MT if I want to. I have pondered this for the last three days.
When all is considered, I'll stick with my gut decision. The 6 MT would be glorious about 5% of my driving time. The other 95%, it would be boring in-town driving; stop and go.
#92
I don't really want to waste any more time but I CAN quote your posts where you contradict yourself. Think before you speak, child.
#93
Originally Posted by Norse396
All you would find are posts he edits after the fact which rarely say the same thing after the edit.... Not worth the time...
Yep, I feel the exact same way. I know he's done it, others know he's done it. Shit I'm sure he knows that he's done it! :grenade: It's not worth another minute to me.
#94
If you can't understand what impact an across the board multiplication of the effective gear ratios by 1.5-2.2 times would have on the performance of the automatic TL, I can't help you.
#95
You don't understand how torque converters work blah blah cut paste blah blah cut paste blah blah blah[/color]
http://members.aol.com/intwg/trolls.htm
Mike
#96
Originally Posted by svtmike
He understands exactly how torque converters work; that's obvious from his posts. Admitting as much wouldn't allow you to continue your rants, though, so instead you resort to personal insults. Classic trolling.
Mike
Mike
He implies that the resulting torque multiplication is a fixed multiply across the RPM band and throughout each gear.
Such is not the case.
#99
No, he clearly DOES NOT.
You didn't understand that, because you didn't understand how gears work, and that if you halved the gear ratios (because again we are talking about ratios here, and although the number gets twice as large, that number is actually at the bottom of a fraction) you would also halve the MPH range that each gear operates in.
That basic and fundamental misconception is repeatedly demonstrated in the above posts, and your attempt to change history now will not be successful. Your above posts have spoken for you.
And while I am on the subject, despite the fact that my post last night completely floored you and stopped you dead in your tracks, you continue your diatribe this morning, by adopting the exact opposite of your previous position, which has been shown to be untenable.
I did not repost my victory or rub it in your face, because I am not like you, and will never be like you.
Your problem is you think a lot of information is better than a little bit of knowledge.
Grow up.
#100
You are so pathetic. I do not imply any such thing. In fact, I have been saying exactly the opposite. You are the one that has been saying that to compare the effective gear ratios you must multiply the automatic gear ratios by a factor of 1.5-2.2. As I have repeatedly stated, the effect of the torque converter is variable, and simple math demonstrate that you cannot simply multiply the gear ratios by a factor of 1.5-2.2.
Grow up.
Grow up.
The converter's torque multiplication effect is neither fixed nor constant, but it IS significant, particularly so in low gear and from a standing start:
For perhaps the 30th time:
#101
Grow up.
Grow up.
Here, let me help you:
EVERY torque converter acts as a TORQUE MULTIPLIER @ lower engine speeds!!!!! But the net effect ISN'T EVIDENT when simply comparing gear ratios alone.
#102
It's good to be able to revisit and consider options.
Exactly why I went with 5AT, it's easy to second guess after the fact which I do at times. I'm enjoying the car when it isn't trying to fall apart.
Can you explain??
#103
So in this forum you tell everybody how wrong they are, in the TSX forum you told everybody how wrong they are and on ModernMusclecars you do the same thing and on ClubTSX and again on TSXclub you did the same thing and at all those places you were banned because instead of adding to peoples answers or admitting that people may say the same thing in different ways you insist on forcing your opinion as the only viable one allowed. You're completely shocked when people don't agree with you after posting untold amounts of links...
It took awhile before you got banned, showing that on average moderators tried to give you the benefit of the doubt.
You've lasted awhile here so if you're true to yourself you'll be banned from here sooner or later. You're batting 99% in the banned department, congrats.
#104
YOU continuously post crap like that and then suggest that it is I who should be "banned?"
#105
Go read what I wrote WAY BACK in post # 51:
I never claimed that torque converters don't further multiply the gear reduction in automatic transmissions. You can't find a post where I even said anything remotely close to that.
I simply questioned the relevance of your incomplete quote and pointed out that a simple multiplication of the gear ratio by 1.5-2.2 times is not an accurate way to compare the gearing of an automatic and manual transmission, and in any event is not what your own articles are saying. The effect of the torque converter is variable, depending on the host of factors discussed in the many articles you have posted.
You are now free to continue with your regularly scheduled rant.
#106
Since we are revisiting posts, how about we take a look at what I wrote way back in post #67:
That is all that needs to be said.
#107
Post 51 came before post 67...
It was not until recently that you came out and said the effect was variable.
In any event, take a look at the posts after post #67, and ask yourself why you continued to argue the point if we supposedly agreed way back in post # 67.
Doesn't make sense, does it?
#108
There is a difference between posting quotes from the internet, and demonstrating understanding in your own words.
Again, POST 51. The words in blue are my own. Pay special attention to the words "AT LOWER ENGINE SPEEDS."
#109
??? trying to fall apart??
Can you explain??
Can you explain??
This is the worst car I've ever owned rattle wise, I've found parts under my car seats and tools (which I'm keeping) and plastic covers on the windshield washer cover keep falling off.
Quality control is something that got completely missed when my car was built and frankly I'm sick of owning it already. Last night was the last straw as my wife had to hold the glove-box while I held the dash to get some peace and quiet from the non-stop rattles this car has.
#110
Why would I repeat what's CLEARLY stated in a link that's quoted in the same post?
In any event, the above posts speak for themselves, and I have better things to do today then continue this pointless exercise.
Enjoy playing with yourself.
#111
I post factual links and discuss technical issues.
As usual you have your facts wrong, please show one instance where I ask that you be banned or that you should be banned. You can't because I didn't.
I said just be yourself and it will happen.... this, is fact.
#112
#113
The better question is why do you repeat everything you post?
The theory is that if I post them often enough you might EVENTUALLY read the.
#114
Because you don't read the original post(s).
Clearly, you are in need of a new theory, as your old one is obviously quite flawed. Perhaps searching for a whole new theory is an overly ambitious project. Consider a more modest goal. Why don't you begin by simply searching for a clue. :clown:
#115
Originally Posted by UminChu
You have no idea if or when your repetitive posts, links or scans have been read or not. You just keep ramming them down everybody's throats whether they like it or not....
I'm not "ramming" anything down anyone's throat. People are free to ignore my posts either by passing over them or by placing me on their "IGNORE USER" list. Why don't you pursue one of those options? :think:
#116
Either they're not read or they are read but aren't understood.
#117
Originally Posted by TLover
Is it too much to ask that you stay on topic?
This guy made this statement way back on page 1:
Start screaming @ him because HE changed "the topic" (which I've been discussing even since).
Originally Posted by Moodie
The 6MT car gear ratio is much higher than 5AT, so pickup and accelaration is better.
#118
Continuing to post the same words, links and scans long after you've been asked to cease doing so is very much ramming down everyone's throat.
Ignoring you is futile. Your posts are quoted in others' responses to them. There are numerous individuals contributing to these threads whose posts merit respect and consideration. In spite of your determination to be this forum's chief troll and nuisance, I still find benefit in perusing threads that you've chosen to hijack.
#119
#120
Why don't YOU?
Does that justify you going on and on about torque converters? And yes, it takes two to tango, so the guy arguing/debating with you is as much to blame. But you have a pattern of arguing/debating with different people in different threads about things have having nothing to do with the original topic.
