5AT question. Low (L) vs Drive (D)
Why and when would you use Low (L) vice Drive (D). I read the manual but still I do not get it as to why one would want to use Low gear aside from going in down hill.
Yup, roadman took the words right out of my mouth. Lower gears provide more power and are better in snow and other bad conditions. And I guess it could be used to slow down too, didn't even think of that. I would just use the parking brake if I had to.
Someone correct me if I'm wrong. I think Low just holds 2nd gear. It will still automatically go from 1st to 2nd, but no more. The 2nd gen TL/CL also had D3 and D4, which a lot of us which the '04 TL still had, but we've discussed that in another thread already. I think Low just equals D2. Anyone else?
Acura says: When moved to the Low position, the transmission downshifts to the lowest possible ratio for the current road speed to provide maximum engine braking. If the vehicle continues to slow, the transmission progressively downshifts to maintain engine braking effect.
When it has shifted all the way down to first gear, an upshift back to second gear is automatically available if speed increases, but the transmission won't upshift further unless the driver moves the selector back to the D (Drive) position where normal transmission operation resumes.
For the reason why to use L mode... if you like to get 1st gear driving impression, you should use L for the start...
Ok... IMHO...
L mode is still different to SS mode... the main reason is to engine-brake... the second reason is to have fun...
To brake...
SS mode won't downshift to lower gear too much... L mode could quickly go as low as possible to maximum your engine brake power.
To have fun...
1st gear:
SS mode would not hold it and rev high. It all depends on how hard you step on your pedal.
L mode would hold it and rev high no matter how slightly you put your foot over the pedal.
I mean L mode has tougher threashold and it will rev higher before jumping to 2nd gear. Maybe I could say SS mode shifting from 1st to 2nd depends on your RPM and your pedal control. L mode from 1 to 2 is based on your speed.
Perhaps, you could feel more different if you personally try it...
To brake...
To have fun...
1st gear:
This is why you buy the 6MT you could do anything you want manually of course.
One thing I hate about SS, during a corner, I can't downshift and apply engine braking accordingly, it just shift to the lower gear. I hate automatics and SS.
Another things is you can't shift from 4 to 2, you have to use 3rd....it sucks.
Ron A and rets - Thanks for the comments. rets may be right, but I'm not sure. SS will stay in 2nd gear until its programming says it has to upshift to prevent engine damage, right? If so, one would hope Low wouldn't let you continue to rev higher and possibly cause engine damage, so it should have the same programming. No?
Team Secretary of Housing
One of the most important reasons for L....
When you catch a Police car in the corner of your eye and you are about 5-10 mph over the best thing you can do is down shift to slow. This will not cause your brake lights to come on and attract the officer's attention. This will only work if you have observed them before they observed you.
Do not try this in heavy traffic though
Originally Posted by Ron A
Programming will not upshift if you are in 2nd gear, but the rev limiter will kick in and the engine will cut in and out. It will not upshift in either manual D or SS 2nd gear unless you tell it to by moving the shift lever. See pages 183-185 in the owner's manual.
I'm thinking this differently.
Acura says: In second, third and fourth, the transmission won't upshift without a command from the driver; the ECU cuts off fuel flow to the engine if there is danger of over-revving the engine. The transmission will upshift itself to prevent engine damage in the rare situation where the fuel cutoff alone is unable to prevent further engine over revving.
Although Acura also says: "the transmission won't upshift further unless the driver moves the selector back to the D (Drive) position where normal transmission operation resumes", I guess, if you keep accelerating, the actions of cutoff or upshift as SS mode does would be executed by ECU, too.
Basically, L mode is quite similar to SS mode in many prospects, but L mode does program to offer the best engine braking by referring to your situation. When moved to the Low position, the transmission downshifts to the lowest possible ratio for the current road speed to provide maximum engine braking. If the vehicle continues to slow, the transmission progressively downshifts to maintain engine braking effect as I posted above.
:licka:
What I said to enjoy the 1st gear power is just the side-effect of L mode... not the main stuff...
rets-where did you get this information: “The transmission will upshift itself to prevent engine damage in the rare situation where the fuel cutoff alone is unable to prevent further engine over revving.” I couldn’t find it in the manual.
I understand what you are saying about L giving more acceleration than SS when used flat out, but the way I see it, for normal driving, in addition to engine braking, the main difference is that if you use L for either acceleration or in snow or on slippery surfaces, you can move the lever forward when you want to shift from low and be in D, which would require no further shifting, but if you start out in SS, you would have to manually upshift each time to get to 5th gear.
Just to sum up, other than for engine braking, L is good if you want lots of acceleration from a stop but then want to go into D directly and let the transmission shift for you from then on, but SS is good if you want to maintain control over what gear you are in.
Great discussion, guys. rets, I think you've cleared something up for me I didn't understand. No matter what speed the car is moving, if I suddenly shift to Low, the tranny will go into the lowest gear it can safely accommodate, right? If so, this IS one big difference from the SS. This is a way to get maximum engine braking without having to think about what gear you could safely manually downshift to. Even manual boxes don't have this functionality.
TLGator, right, the tranny of 04TL is programed to downshift into the lowest gear it can harmlessly accommodate. Ron A, I think your evaluation about "L" is correct.
http://hondanews.com/CatID3014?view=t&page=1
The info I have posted above is from "powertrain-part 2". I suggest to copy all of them into one single file at your computer, it's the quite good reference beside the owner manual.
Yes you can
As to starting in snow, use SS and tap up to start in 2. That's best to control wheel spin and traction. The last thing you want to do is be in L when its slippery and you need traction.
Originally Posted by 6mtV6
So it's ok to shift to L when the car is in motion?
Yes, as the info is addressed above, L mode will downshift to provide the maximum engine brake for you accordingly. Except shifting to N, you could move your lever among SS, D, and L any time(ECU would do some smoothly transaction for you).
Originally Posted by Lore
By that same token, would one shift to L to immediately get the lowest gear they could get for acceleration purposes?
In this case, this is better than SS, because if you change to SS, you have to move the lever once to go to Ss, and then 3 times to go from 5th to 2nd, which is a lot of movement considering shifting to L is one push of the lever.
TLDude876
Dec 28, 2016 03:18 PM
HeloDown
Sep 8, 2015 06:51 PM
