Are 3rd Gens Having Motor Mount Issues?
Old Oct 8, 2007 | 02:55 PM
RUF87's Avatar
Lead Footed
FYI - if the 3rd gens use the same motor mount as the 2nd gens, you will want to check this link out.
Ruf
https://acurazine.com/forums/showthr...68#post2709468
Old Oct 8, 2007 | 07:35 PM
csmeance's Avatar
From what I have read here, the only problem we have had is the mounts binding and needing to be neutralized on a few TL's.
Old Oct 8, 2007 | 09:24 PM
Inaccurate's Avatar
The 3rd Gen uses different mounts. Even the way the mounts bolt-up to the engine block is different.
This was a project that I was pursuing until I found a better project. Here is the info that I have accumalated.
Innovative Mounts for 1998-2002 Honda Accord V6 (click here)
From my researching (comparing oem part numbers with TL and '02 Accord) and "looking under the hood" of 2nd and 3rd Gen TL, these mounts will work on the 3rd Gen TL IF you replace the engine bracket that bolts to the engine block with the bracket from a 2nd Gen TL. The assumption is that the mounting bolt holes are present in the 3rd Gen's engine block to bolt the bracket from the 2nd Gen. From looking, the front mount looks like for sure it will bolt-up. This would be a great starting point to control the engine twisting under loading.
Innovativemounts seem to be VERY WILLING to make custom brackets for a reasonable charge. I talked with them about doing a direct bolt-in for the 3rd Gen TL. They were ready to work with me..... I then found a better project for my TL that I am currently pursueing (unrelated to engine mounts).
Reply if you want me to be more clear and explain better.
Old Oct 8, 2007 | 10:04 PM
04accordcpe's Avatar
347hp/300tq @ 4psi
^^ i conquer. 2nd gen TL/CL use different mounts then 7th gen accord/3rd gen TL's.
Old Oct 8, 2007 | 11:01 PM
OMP Prelude's Avatar
13.19@105.48MPH
If they make it for the 3g TL's I would be intrested, even in a group buy or not
Old Oct 9, 2007 | 06:58 AM
ggesq's Avatar
This thread is being moved out of the Performance Parts & Modifications subforum. Please read the following prior to posting in this section: https://acurazine.com/forums/announc...nouncementid=7
Thanks.
Old Oct 9, 2007 | 07:15 AM
HQTL6SPD's Avatar
Old Oct 9, 2007 | 09:38 PM
Inaccurate's Avatar
But, here is the teaser. These mounts MIGHT fit the 3Gen. If you replaced the 3Gen's brackets (and use 2Gen's instead) that attach to the engine block (as shown in the illustration below), I think the mounts will fit. I am not pulling this out of my hat. I have a 2002 2Gen, and I have my 2006 3Gen. I compared both cars side-by-side. I took some quick-n-dirty measurements with a dial caliper. Although the 2Gen and 3Gen have differently designed mounts, the mounts have the same dimensions. The only thing that appears to be different is how the bracket (red arrow in pic below) attaches to the top of the mount. This is why a 2Gen mount needs to be used on the 3Gen. The only WILDCARD appears to be IF the 3Gen engine block has the same bolt pattern as the 2Gen engine block. And, it is a good bet that Honda did not change the bolt hole locations in the engine block. The only other WILDCARD is if the exhaust manifold would interfere with the different bracket because the exhaust manifold does fit tight next to the bracket.
Old Oct 10, 2007 | 11:36 AM
347hp/300tq @ 4psi
why go through that?? read my post, they just FINISHED making mounts for the 7th gen accords which is a direct bolt on and will fit 3rd gen TL's. im picking up my mounts this week..
Old Oct 10, 2007 | 08:34 PM
Inaccurate's Avatar
Do you know the part number ? I checked their web site and didn't see it. Thanks for the help blusap !
Old Oct 11, 2007 | 01:04 AM
ussi's Avatar
I (don't) whine.
^^I'm also interested in motor mounts..
Old Oct 11, 2007 | 10:51 AM
Excelerate's Avatar
Former Sponsor
Actually Innovative has already produced a setup for the 7th gen Accord. They just finished it so I will keep you guys updated as I get more info on the finished product and pricing.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
wilztlxs
Dec 1, 2015 09:16 AM
carz0159
Sep 20, 2015 06:11 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
