3rd Brake Light Replacement - 05 TL
Anyone know the correct way to pop the cover off of the third brake light for an 05 TL? It sits at the top of the back window and there is plastic around where you would access the light assembly. I am assuming clips but where, how many, best way to remove?
Thanks!
Steve
Thanks!
Steve
Welcome to the forums. The pictures don't tell much, though, but you just pull straight down and the cover will pop off.
You should always check out THE 3G GARAGE first.
F-046: DIY: 3rd Braking Light Cover Removal
https://acurazine.com/forums/showthread.php?t=102009
lol, yeah. already replaced the switch so its working fine. I just want to remove it so i can reapply the liner. its falling off and looks like shit. Hopefully its as easy to take off and put back on as everyone says it is....
Last question for you helpful people!
What is holding the housing in place, just those two tabs when you pull straight down and push straight up? what about that rubber lining at the end facing the rear of the car. The upholstery is coming off and I am wanting to replace the lining, just don't know how difficult it would be. (I am wanting to replace the entire headliner but i cant even remove the vanity lights that come on when flipping the visor. It literally will not come off with all the force i put in to it.)
Any advice will be greatly appreciated!
mada51589
Jan 9, 2025 04:40 PM
wusty23jd
Sep 24, 2015 11:41 AM
Skirmich
Sep 15, 2015 06:41 PM
asahrts
Sep 4, 2015 05:55 PM
