3rd and 4th gear pressure switches
I spoke to the service department a my local acura dealership and inquired about the 3rd and 4th gear pressure switches. He said he had never heard of such a thing. I would assume he would know what I was talking about since I believe I have heard of them discussed in this forum. Or am I wrong about the name completely? Also should this worry me thato he has never heard of pressure switches? Thanks
You stated it right, and it would concern me if he had never heard of them. Local folks have surely purchased them from their parts department before and inquiring the service (sales) team the same.
If you talked to him, then he's gained enough car knowledge to be in a speaking position with the public.
Just order them and do it yourself, takes like 30 minutes to install.
It's more of an under the table thing discussed on this website, there's no official maintenance period regarding these.
You'd likely be better off replacing your transmission mounts with that mileage in all honesty. That will see a difference in shifting more than replacing these did, at least for me.
Don't fret over the tranny failing, enjoy your car and perform the outlined recommended maintenance in your owner's manual. I'll let others chime in on 3x3s.
I'd order them and add them to your to-do list.
Peace of mind is what you seek.
I thought my transmission shifted fine as well, after replacing the mounts (all three), it shifts much finer.
I noticed zilch after replacing the pressure switches.
How much of the transmission must you access to replace the switches?
So presumably I could do this myself with no previous mechanical experience? I appreciate your patience in answering my questions.
If you have an 04-06 the part #s are:
28610-rke-004
28600-rke-004
You can do this by yourself, might as well change the transmission filter while you're at it.
You'll have enough left over to buy a cold air intake in comparisons to letting the dealer do this for you.
28610-rke-004
28600-rke-004
28610-rke-004
28600-rke-004
28610-rke-004
28600-rke-004
https://acurazine.com/forums/third-g...729149/page16/
https://acurazine.com/forums/problem.../#post15318910
Read up on the OP of the DIY, the other thread clarifies the new part numbers I've already given you.
The job requires one of each, assuming you have a 04-06 automatic TL. Do you?
I would safely assume only members here have changed theirs. Again, it is not something an Acura dealership would perform as part of regular maintenance...ever. Nor would they bring it up on a multi-point inspection. If they've heard of it, it's likely come from this website.
I'd assume no Acura TL owner has had these replaced if they're also not a member here.
To redirect your concern about your transmission, I'd again encourage you to replace your transmission mounts with that mileage. These are pics of mine, with similar mileage, and when I felt my transmission was shifting fine.
To redirect your concern about your transmission, I'd again encourage you to replace your transmission mounts with that mileage. These are pics of mine, with similar mileage, an when I felt my transmission was shifting fine.
There is no guarantee that this will prevent any damage to any transmission.
Why are you so concerned about your transmission? If it's not giving you trouble and you do perform the outlined maintenance schedule for the transmission...go enjoy your car.
A user on here, I believe it was IHateCars that had a discussion about the transmissions with someone. It became lore on here to change them on occasion, there is no interval outlined by Acura and if you were to call them, they'd be just as puzzled as your service adviser was.
A user on here, I believe it was IHateCars, had a discussion about the transmissions with someone. It became lore on here to change them on occasion, there is no interval outlined by Acura and if you were to call them, they'd be just as puzzled as your service adviser was.
Why are you concerned with a rebuild...
Is your transmission giving you any signs of trouble?
Most all of the individuals that performed the 3rd and 4th gear switches swear by a before/after difference, maybe they had tranny issues, I dunno. I changed them at 105,000 miles and noticed ZERO difference.
I changed my mounts and noticed 100% difference in what I thought was already fine shifts.
Yeah, just enjoy your car and listen to it when it talks to you, maintain it and it'll last a long time
Extra word of advice, check you dipstick regularly, at least once a week, there is no low oil warning in these cars. Most discover this when VTEC stops kicking in.
I should add many people not just people.
here is the thread I made earlier this year about scientific facts why pressure switches should get replace.
https://acurazine.com/forums/third-g...lained-926831/
OP- do the switches as a preventative item. The research and work has already been done by experienced & knowledgeable members that have worked in the industry. Even if you have zero symptoms of tranny flare, harsh shift, shudder, etc.
The interval for changing the switches is every 50k miles.
OP- read this thread: https://acurazine.com/forums/third-g...721508/page24/
Just had the three pressure switches changed on my 07 type S as prevent maintenance.I religiously do a 3x trans service at the dealer 2x a year.Trans shifts were a touch bit lazy before changing them.All I can say is the upshifts now are quick and crisp.Downshifts as well! When using paddle shifter the gears snap off much better.I feel a big change in my car so im happy.Plus knowing the added benefit doesn't hurt.
Didnt notice any change when I did the switches on my TL-S. My TL upshifts slightly quicker and firmer (the way I prefer) than my TL-S, and it still feels that way even after doing the switches on the S. I wish I knew why this is, since AFAIK, the transmissions are the same (both cars 2008)
I have close to 240K miles on my TL and replaced my switches less than 20K miles ago. I did it because I was experience some shuddering in the 2nd-to-3rd and 3rd-to-4th shifts. The shifting seemed to improve after the new switches were installed but now the shuddering is back. It only happens under very light acceleration. If I accelerate a little quicker I don't have the problem.
In addition, my transmission seems to be shifting very slowly between park, reverse, and drive when the tranny is hot. Everything is fine when it's cold but after driving for a while, there's a noticeable delay after moving the shift lever from drive (or reverse) to reverse (or drive).
Is my transmission dying?
