3" Lenses for Projectors
I'd get them because they are the only other alternative to OEM, unless you want to spend $130 - $170 on an authentic set which offer a slight difference in color at the cutoff , but the difference in cutoff sharpness is nearly identical.
Oh, and check here for some pics and video of those same lenses in action:
https://acurazine.com/forums/showthr...=712916&page=2
Chapter Leader (NY/NJ)
those are the ones i got. i believe he has the same ones but under a different name for 10 bucks less. dont quote me tho. same exact description but name says like benz and not acura TL.
I have had two TL's. My first one a 07 base I bought the ZKW replicas and I wasnt all that impressed. They for sure added SOME color but not nearly as much as I thought they would. Also, I was expecting a super sharp cutoff but the cutoff did not change in sharpness from stock whatsoever.
I now have a 07 Type S and im contemplating spending more and getting the true ZKW clear lenses. Does anyone know whats involved with this required spacer? Whats the best way to make it fit correctly and what do you have to do?
Thanks,
James
Thanks,
James
Thanks,
James
Thanks,
James
Thanks,
James
Thanks,
James
Awesome thanks. I guess regardless of what I use I will test the output prior to putting everything back together and I can get the cutoff exactly how I want it.
Also, I know the real ZKW lenses have a notch on the outside lip. Does anyone know if it makes a difference on what position the notches are located at?
Former Sponsor
If I put two pictures here of output, both from ZKW-R and real ZKW and ask people to identify each then 9/10 people wont be able to tell the difference, especially if the wall shots are from <20 feet. At 50+ feet the difference in cut off sharpness between ZKW-R and authentic ZKWs is pretty evident though.
Thanks JNC then maybe thats what explains why I only noticed a little more color but no sharpness change when I went with the ZKW-R's. I did not modify the cutoff shield at all.
So if I go with the true ZKW lens then there really isnt a need to modify the shield as long as I make the correct spacer? I would really prefer to stay away from modifying the shields if possible, but I for sure want a little more color and sharpness. If you have the time would LOVE to see some comparison shots of real ZKW next to ZKW-R lenses.
Thanks,
James
Thanks,
James
InFaMouSLink
10-27-2015 06:51 PM
Trplezero
09-03-2015 10:25 PM
