3-Blink turn signal
3-Blink turn signal
Can this be done?
Ive been driving around my wife's 2015 Civic and man i love that 1 click 3 blink signal to change lanes..
When i get back into my TL i forget it doesnt have it..
Really nice feature to add to the tl if its possible without breaking the bank or having to buy some module to install..
Can this be done?
The 3 blinks wouldn't be so difficult but you'll need to have a turn signal switch that will move accordingly (possibility of not clicking when pressed/half-pressed in one direction, otherwise you'll only end up making the switch click most of the time).
You will definitely need a module to control the number of blinks, a small microcontroller can do this job just fine (pretty simple).
in the TL, I always do the half click and leave my hand there then lift my hand after.
so, its almost as similar to the automated three click found in newer cars.
I daily drive a Kia that has the three click implementation and I only need to slap it once and take my hand away, so I do feel your pain
Can this be done?
I had a 2015 Civic as a loaner and that thing irritated the frick out of me.
I'm old school, signal--leave it there--manually reset it.
In the Civic it either wouldn't stay signalling, wouldn't signal at all or would signal forever and I couldn't turn it off.
Or when I did 'turn it off' it would suddenly start signalling the other direction. I also noticed the lever doesn't click or travel as far as a 'traditional' signal-lever.
It came to the point where I was using hand signals to merge cause I refused to use the stupid turn signal.
You slightly press on the turn signal arm either for left or right and it doesn't "click" in place. It makes the turn signal blink 3 times. This is good for lane changes for people who forget to disable their turn signal after changing lanes. If you want to signal at an intersection, you press the turn signal completely and it clicks into place like a classic turn signal.
If you drive a BMW, this is all irrelevant, the turn signal is an option.
havn't experienced this "3 blink" feature, but sounds cool
i see other cars implemented it using a relay, i don't see why its not possible to do on the TL
gatrhumpy im sure you can get it done
Sorta off topic... but is that what that shit is?!
Hahah. It is a bit sensitive. I guess it's not for everyone. I love that feature. My brothers cars also have it and I am so use to it when i driver her car. Ive never had a problem with it.
Would be nice to have it on the TL too
Same, I just press it a little, but not enough to click it into the "locked until turns complete position." It will signal for as long as you hold it there, usually I just do it for a few blinks.
My last car was kinda busted and for right turn signal it was manual on/off only.
I also was driving my girlfriends BMW and I think it has a similar system. It was pissing me off by not staying on when I thought I fully engaged it. No wonder beemer drivera never use their signals.
navtool.com
Nov 16, 2015 09:05 PM
