22.5k maintenance
Old Nov 26, 2007 | 10:48 PM
ACURAFANANTIC's Avatar
22.5k maintenance
i'm due for another maintenance at 22.5 k
i think its an A1. can i get this from a non dealer mechanic shop instead since its just oil change anyway. dealer charges way too much over 130bucks n take too long.
Old Nov 26, 2007 | 11:38 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Did you really pay $130 for A1 service? To my knowledge, A1's are only an oil change/tire rotation. The dealership that I go to charges $34.95 for it. I didn't feel like waiting all day for an oil change, so I just got my service done last week @ 18.6K mi., at a regular car maintenance center. They changed the oil (5w-20)/filter, and rotated the tires for $26. Afterwards, I personally reset the maintenance minder on the MID.
So I think you'll be fine.
Old Nov 26, 2007 | 11:46 PM
OMG! those bastards told me all this was done:
A1- 7.5k-22.5k-37.5k-52.5k-67.5k-82.5k mile service
Change Engine Oil & Filter
Check Clutch Adjustment & Fluid Level
Inspect Front Brake Pads, Rotors and Calipers
Inspect Fluid LEvels
Adjust Parking Brake
Inspect Exhaust System
Inspect Tire Wear & Set Tire Pressure
Check hoses, belts & coolant level
check wiper blades & windshield washer fluid level
inspect power steering fluid level
inspect transmission fluid level
inspect front suspension & steering operation
rotate tires
and over 400 bucks for this B1
15k/45k/75k mile service
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Inspect Front & rear Pads, Rotor & calipers
Inspect all fluid levels
adjust parking brake
inspect clutch operation, adjust freeplay and check fluid level condition
adjust all belts
inspect suspension mounting bolts for tightness
inspect exhaust system
inspect tire wear and set tire pressure
check hoses belts and coolant level
inspect battery and clean terminals
adjust alternator belt
inspect valve clearance
check wiper blades and winshield washer fluid
lube door, hood latches and hinges
rotate tire and balance
inspect and clean spark plugs
inspect cap and rotor
road test
Old Nov 27, 2007 | 12:31 AM
Bearcat94's Avatar
AZ Community Team
Check the Owners Manual for A, B and 1, 2, 3, 4, 5 Service Items.
https://techinfo.honda.com/rjanisis/...606O00208A.pdf
According to "The Book":
A = Change Engine Oil
1 = Rotate Tires.
That's it. Although most of use will also change the filter and have other fluid levels checked (gratis).
Further Maint is NOT mileage based, except for a few exceptions. IOW - Just follow the MID.
"The Book" also says:
Your authorized dealer knows your vehicle best and can provide competent, efficient service. However, service at a dealer is not mandatory to keep your warranties in effect. Maintenance may be done by any qualified service facility or person who is skilled in this type of automotive service. Keep all receipts as proof of completion, and have the person who does the work fill out the maintenance record.
Remember, it's YOUR car. YOU tell the service center (dealer, indy, whatever) the work YOU want done.
Old Nov 27, 2007 | 06:20 AM
ggesq's Avatar
Originally Posted by ACURAFANANTIC
can i get this from a non dealer mechanic shop instead since its just oil change anyway. .
acuratl26
Apr 23, 2020 07:30 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
