2008 TL - TIRE PRESSURE - Is yours Even?
Seems like my TL's tire pressure is never right. Usually they will be somewhere along the lines of 33's and 34's. Today the outside temp got into the 60's and the pressure was up into the 37's and 38's.
Does anyone's tires stay the exact same in relation to each other? For instance, the fronts stay at 33 and rise with the temperature ,and the rears at 32 and rise the same?
Or do yours sort of dance around a few pounds here and there?
yakuzapop
Its changing all the time....
It changes depends on the temperature as well.
I think around 30 psi is ok...
Registered but harmless
Received 1,150 Likes
After that, ignore any fluctuations. PSI will increase as temperature increases, both ambient temp and temp of the tire due to friction during driving.
Set the cold PSI to at least the minimum stated on the driver's side door jamb sticker- 35F/32R for 6M, 33F/32R for 5AT. You can increase the PSI, up to 40 lbs. max, to adjust the feel of the car.
94 DC4 RS LSV/Turbo
I drive hard so I am set to 34 psi all around usually i read 37 or 38 psi on the mid... digital gauge in the mornings read 35 or 34 depending on the temp
Originally Posted by Will Y.
Measure the tire pressure with the tires COLD, i.e. driven less than a mile in the a.m.- that's when the tire PSI should be set.
Originally Posted by vinnier6
i have an auto, and mine says 35f/32r
FWIW, my TL is at 36F/33R, although it has 32F/32R on the door sticker.
LIST/RAMEN/WING MAHSTA 짱
My MID often indicates a 1 psi difference in tire pressures, even though I am fanatical about having exact tire pressures all around. My compressor and my digital tire pressure gauge always read the same, but the MID is often ~1 psi different. BTW, fwiw, my settings are 40psi/37psi, F/R.
The air pressure in your tires is also a function of temperature. As a general rule, the pressure will increase 1 psi for every 10 degrees F in temperature. So if you check your pressure on a 40 degree morning, and then things warm up and you're taking your car out for a spin on a 70 degree afternoon, you should expect to see your tire pressure about 3 psi higher than when you set it.
I set my tire pressure according to mfr recommendation 33/32 (f/r), and the MID is quite accurate. Higher pressure gives a more "jumpy" ride, particularly over highway expansion joints, which I dislike.
AZ Community Team
Received 7,771 Likes
Uhhh.... YEAH. Especially if your running the MXM4 tire. Their MAX cold pressure is 44 psi.
When cold I find my MID TPMS to be within a pound. Usually I've got 2 dead nuts, and 2 off by a pound. Sometimes they are all right - I guess, maybe those two are actually off by ~1/2 pound, but it only shows whole pounds.
Anyway, I've got my '07 TL-S set to 34 Front /37 Rear (yes, that's correctly typed).
Originally Posted by alextclam
I have an auto TL-S and my PSI is 35F/34R after driving a couple of miles. What kind of results will I get if I bring the rear down to 32?
Generally, lower rear tire pressure will reduce understeer (plow) in our FWD cars. You may not notice this until you are driving on a track or close to the limit.
The lower tire pressure may also soften the ride and impact harshness, but at the expense of stiffer sidewalls/more responsive steering feel. I don't know if many people can tell the difference between tires at 34R and at 32R in normal street driving, though.
Originally Posted by lldknyll26
My psi is 45/42. A bit too high?
But seriously, yes, I think it's too high for street driving. You will likely get excessive wear in the center of the tread, particularly on the fronts. I don't know if you have impact harshness or a jiggly ride, but bringing the pressure down to 40F/37R may make the car feel "softer" and maybe less edgy.
Yanks in '08!
Is that your COLD pressure (measured with gauge, or MID before driving more than a mile)?
And that brings up another question, if less in the rear reduces understeer, then what does more in the front do?
AZ Community Team
On a *single tire*, when you increase tire pressure, the amount of tire in contact with the road gets smaller. Not side-to-side so much, that's governed more by the width of the tire/tread (235, 245, etc). But the contact patch gets narrower front-to-rear.
So if you increase tire pressure at the back of the car, you have reduced the amount of tire in contact with the road. The less tire in contact with the road, the more likely to lose traction.
Therefore, if you want to reduce understeer (or induce oversteer) on a FWD car, you put MORE pressure in the rear and less in the front. Reduce the amount of rear tire contact and increase the amount of front tire contact.
Made sense to me; day-to-day driving pressures within reason of course.
Ran 36 F / 43 R at an AutoX last night and the rear was just a little bit twitchy "at the limit". Never had that before.
Thanks for th responses so far everyone.
I also tested with a old school tester that shoots the stick out and it read 33 in the fronts, and 32 in the rears. The problem is that the tires never seem to be in the same spot. For instance in the morning I may see them at 33 in the front left 34 in the front right
35 in the rear left, and 34 in the rear right. Then they dance all around. Next day they are a few up, or down.
What is considered a good temperature outside to test the cold temperature at? I am in CT and the temp has danced from the high 30's to the mid 60's so that can definitely be the reasoning.
Just want to be sure the tires aren't all different so I get uneven wear. Think I'm gonna plan to get a better gauge, do the cold pressure test and even them up to 33 fronts and 32 rears (2008 Base TL), and then see if the TPMS is more accurate. I'm not a huge fanatic on it being dead on so it won't bother me as long as I know the hand held reads accurate and I know the right amount is in the tires.
I still say if they are going to put a system like this in the car, they should spend the money to make it as accurate as possible, or don't bother putting it at all
AZ Community Team
The cold pressures will dance around some, especially this time of year, where one morning it's 60* and another it's 45*.
Here's what I do. I know my guage is *very* close to the MID - like I said before, within ~ 1/2 pound. So, whenever I use the car the first time for the day or after it has sat for a good long while (3+ hours), I'll see what the MID says.
If all the pressures are close to where they should be (with ~1 PSI), I let it ride. If they're off, I'll keep an eye on it for the next day or two. If they remain off, I go adjust them.
Good news is, with *warmer* weather coming, cold pressures will increase. So adjustment is going to be letting a little air out. You can do that in the garage/driveway; no need to go looking for air.
1fatcrxnem1
22
06-01-2018 01:23 AM
NBP_BALLER
09-23-2015 08:18 PM
HeloDown
09-08-2015 06:51 PM
