2008 TL-S, 80k miles needs new tranny = bad luck?
Greetings. I've posted a few times here, but this is my first thread.
Made a move from Salt Lake to Denver recently, and had to ditch my 2013 Honda CNG Civic because there simply aren't enough CNG stations here in the Denver Metro Area to justify hanging onto that car. Was able to unload the Civic for $8k, and found what appeared to be a very well-maintained 2008 TL-S with 74k miles up in Boise for $13k. Was willing to spend the extra $5k for the Acura since I've wanted one for a while, liked the low mileage, and because everything looked legit as far as the paper trail goes (no accidents, 2 owners prior to myself, maintenance records from dealerships for oil changes, timing belt done last year at dealership, etc.).
Well, as soon as I got the car I started doing some reading here, and did the following right off the bat:
Took my pops for a ride last weekend and he said we really needed to take it into his transmission guy. So we dropped it off this morning and the diagnosis was that the transmission is, in fact, on its way out. Our guy didn't like the idea of using the Redline in the tranny, and suggested that swapping to the "Acura approved" formula *might* fix the issues, but he was highly skeptical about that possibility. Also turns out that at least one of the engine mounts has broken. Not sure if that happened while I had the car or before, and while it'd be really easy to blame the former owner for these issues (which is precisely what my pops did), I'm not sure I can do that given the maintenance records that were provided and the fact that when I swapped out the fluid for the Redline the tranny fluid in there looked very clean (no fragments or anything alarming). Also performed just fine after the swap.
Just gave my guy the go to rebuild the transmission and was just looking for a sense from the group here about the following:
- Swapped to full synthetic oil
- 3x3 transmission fluid swap - used Redline Type-F racing
- Replaced tranny pressure sensors (per posts here)
- Replaced spark plugs
- Replaced air filters (cabin, engine)
- Just bad luck on my part? Seems like the general consensus, both from these forums and from my guy, is that the trannys in these Acuras are less-than reliable.
- Anyone else out there with a rebuilt tranny? If so, how long should I expect this to last? I like to think that I take good care of my cars, and plan on taking REALLY good care of this one (love driving it - when it's working properly! Heckofalot better than the I4 Civic I endured for the last 4.5 years), but sorta smarts to have to shell out $3.8k this soon into my ownership. I've seen some guys on here with 300k+ on their 2008 TL-S and was hoping to get there myself, but maybe not if the tranny is going to be this finicky!
The fact that your TL is an 08, I would say this is bad luck. The 04-06 transmissions were known to be somewhat fragile, however the 07-08 transmissions were refined and are much more stable. I would have a close look at the maintenance records and see if any jobs were done recently. If so, you could get the dealership to check/warranty some work. (I would not mention any work that you have done yourself, simply because the dealer will most likely use that as an excuse to not warranty anything). You paid top dollar for this car as well, so having the transmission go out so quickly sucks balls. Did you double check your pressure switches? Just make sure those are clipped in and installed correctly. Your symptoms of high rev shifting sound irregular for these cars.
Im sure there will other members on here who will be able to chime in more.
Latent car nut
Received 2,006 Likes
Right off the bat I saw a red flag in your post in that you used Redline ATF instead of the Honda DW-1. While this may or may not have been the cause of the transmission failure, it certainly didn't help things.
So while I don't know if we can blame the fluid, it is definitely a wild-card in this scenario, and those contemplating an ATF switch will hopefully see this thread and take it into account when doing so. Will I be using Redline again? Nope. Not going to risk it and will be sticking with the recommended ATF going forward.
Indeed. Definitely hurts. >.<
Your transmission is failing. I'm gonna try and be as kind as possible, but the amount of Redline Type F you used doomed your tranny. It is well documented not to exceed a 2:1 ratio of Type F fluid. At first the trans will feel like shifts are better, but as the detergents begin to break down after the first 5k or so the lack of friction modifiers from too much Type F begins to show, in your case hard shifts or "flairing". The transmission does need some friction modifiers to function correctly but by using only Type F fluid you essentially removed all of them from your trans. It sounds like it is too late to drain and refill to fix your problem.
The red flag for me is using only Type F Racing fluid. It has zero friction modifiers, and a higher viscosity (written by Redline), not sure how the viscosity differs from Z1 or DW1 tough. You should have at least used a mixture based on the main transmission fluid thread (D4/Type F/Racing), or maybe stuck to D4/D6.
I'm not saying the racing fluid caused the transmission failure but I remember reading in the main transmission thread that people had problems with only Redline Racing fluid in the past.
EDIT: mdnborg beat me to it.
For my own edification and in the hopes that others will see this thread, could you point to where the 2:1 ratio is "well documented"? I also wouldn't mind any sites/materials about transmissions in general so that I can get a better understanding of why the fluid itself may be responsible for the failure here. I did read quite a few threads about what type of ATF to use, and the Redline was usually the one that won out which was why I went that route. I (obviously) just didn't read enough - I was super excited about getting my hands on one of these cars and wanted to "treat her right." Looks like I failed - to both her detriment and my wallet's.
And just to clarify, when you say 2:1 ratio, do you mean Redline:Honda or 2:1 Honda:Redline? Thanks!
Redline Type F racing doomed your transmission and here how it come down play by play.
1. Type F ATF wasn't even recomended by Redline themselves, they recommended D4 ONLY.
2. You drain too much fluid and reintroduce too much new fluid at the same time (this can happen even you using the DW1) as too much ATF causing the clutch pack to swell up and since it swell up it change in fluid pressure.
In your case prove internet is a dangerous place to acquire information as you really have to navigate through the mine field. As in this case you learn the hard way which cost money and time.
3. People here always recommend a mixture of DW1 and Type F, NO ONE run just the Type F.
4. The 07-08 AT is robust and not by any mean its fragile as many member here has more than 200k miles on their original AT.
I own 3 TLs (1 Type S, 2 Base and a 06 RL) and I have not run into any issue with the AT AS LONG AS you keep changing the fluid with DW1 (3 quarts every 15k miles) and pressure switch (every 100k miles). My Type Slow has 68k miles solid miles through my ownership and yet it show no sign of "acting up".
I follow a 2:1 ratio of Redline Racing (Type F) to Redline D4 (stay away from the Lightweight Racing). I know of many people that run this same formula for the performance benefits in terms of shift quality, transmission longevity and reduced clutch pack wear. I would advise you to read through this thread extensively: https://acurazine.com/forums/third-g...ng-atf-834299/ Most people move away from the OEM Honda DW-1 (this fluid replaced the Z1 fluid) when looking to increase trans performance as this transmission fluid carries a lot of friction modifiers which help to encourage the transmission to actually "slip" into gear, promoting smoother shifts but at the same time also promoting clutch pack wear. With Type F fluids, friction modifiers are reduced, making gear changes harder and also causing unintentional transmission behavior, but clutch pack wear is kept to a minimum. I have seen many people complain that Redline ruined their transmissions however in most cases, the 2:1 formula was not followed.
The following 2 users liked this post by mb.3g:
andrewg (08-28-2018),
rightwinger59 (08-27-2018)
I would try a fluid swap with DW1, a 2x3 or 3x3 would be ideal, $100ish worth of fluid is worth a shot instead of a rebuild. Since you have no friction modifiers right now, it wouldn't hurt to introduce some to the current fluid. It may help, it may not, but if it does, you saved a couple thousand dollars.
But it may just buy you time temporarily as well and push the rebuild back only a little bit. Considering you won't know how much damage is done to the transmission until you open it up, it may just be better to rebuild it now and not have to worry about it again. Considering you want to keep this vehicle for the long haul.
[**UPDATE**]
Finished reading the thread recommended by mdnborg above. It is quite lengthy, so I will summarize it here with the hopes that other folks will avoid the issues I've had:
And speaking of going forward, I will probably hold off on re-introducing the synthetic fluids until the warranty on this rebuilt tranny has run its course (12 months or 12k miles). However, I find the arguments presented in the thread compelling and will probably reintroduce the Type F fluid in the future, for the reasons discussed in the thread. Thanks to those who replied here - I appreciated the feedback and hope others will find my experience useful and instructive.
- Beginning sometime in 2010 or 2011, several members of these forums started experimenting with synthetic "Type F" or "racing" automatic transmission fluids ("ATF") in their third-generation TLs. The most popular brand was Redline, but others were discussed in the thread as well.
- The main reason for these experiments concerned the levels of "friction modifiers" ("FMs") present in the stock, Honda recommended ATF, which was originally a product titled "Z1" but has since been replaced with "DW-1".
- According to those advocating for the Type F fluids, Honda introduced too many FMs into the stock fluids in order to attain "butter-smooth" shifting, which leads to increased wear and ultimately reduces the life of the transmission in the TL. Type F fluids, by contrast, have less FMs, which leads to quicker shifting and hence less wear, thereby extending the life of the transmission (in theory). This post by Inaccurate is pretty much a great summary of the entire thread.
- The main question, then, and the main purpose of the thread linked above, was to determine the proper amount of Type F fluid to be introduced into the transmission.
- Several users reported no issues using almost 100% Type F fluid in their TLs.
- However, I would say that the majority of those using Type F fluids experienced "flaring" when shifting between 2-3 and even 3-4, just like I was.
- Many users reported that reducing the level of Type F fluid to 65% or below cured the flaring issues.
- A detailed explanation of the mathematics behind the % calculations can be in this post. Otherwise, the first post of the thread has the proper formula for doing ATF changes with the aim of hitting the 65% mixture target. To date, many users in the original thread and this one have reported zero issues using the synthetic fluid mixture of 65% or below.
tommyg55
07-01-2013 05:20 PM
peter_bigblock
10-20-2005 02:13 PM
