2007 TL Switchblade Key
#281
Trucki!!
Originally Posted by Fulani has a TL
Soooo......
Havent received my key yet. Want to know if anyone has had any luck whatsoever with this.
#282
key fob for 06 TL
Originally Posted by lembowski
Finally found the thread on the accord key mod guys, if you have any questions shoot me a pm on it. i will however not answer questions that are clearly answered in the thread, so read first. Until someone posts ths fcc code on the 07 key I can't research it:
https://acurazine.com/forums/showthr...ghlight=remote
Hey, new to the site and was interested in the 07 TL switchblade keys for my 06 key. are u still doing them or do have any updated information.
#283
Trucki!!
#287
I originally ordered Mem 1 key, But now I am thinking about ordering the Mem 2 key.
Sucks how they can order something that they dont even have
HEy, What kind of car do you have and how are you going on with getting a switchblade key moded for your car.
#288
I have an 06 TL, cut apart the valet key, cuz i really dont hand over a "special" key to the valet, rather just give him the keys that are already in it. At this point I don't know really what to do with it because I haven't been able to see the actual switchblade key, I suspect I would go according to JK Autosports instructions and pictures. Seems pretty doable and more realistic to me because I dont have access to CNC machines, Lathes, and anything of that sort.
#289
Koo, hey did you order your key from the dealer
#290
Originally ordered from Pohanka Acura in Northern VA. They took the money and now say "we will call you when the part comes in" that was for Mem 1. Going to call Acura of Escondido tomm and see if they have any Mem 2 available
#291
Well... No key for me as of yet. I did order the Mem1 key and will call the dealer to see if I can switch over to the Mem2. Maybe I'll get lucky.
Either way I'm still moving ahead with making a prototype key to test if machining the switchblade key is a good way to go.
A note to those interested in grafting an '06 key onto the '07 with JB weld.
JB Weld "IS" epoxy based and is a 2 part mix. IMO... the best bond will be achieved with a lap joint. The lap joint should be as flat and as square as possible.
This will maximize the surface area of the bond. You also want to make sure that when you mix parts A and B they're as close to the same amounts as you can get. Too much or little of one and the JB weld will be either brittle or will never get hard. Make sure the JB Weld is as new as possible. Finally... make sure that you clean the key halves with alcohol or some other solvent so that there's no oil on the surfaces to be bonded. Your fingers have enough oil on them to prevent the JB weld from bonding properly.
Good luck guys... I'll have something for you real soon.
Pete
Pete
#292
'04 TL w/Navi SSM
Thanks for the update FLBusa.
Are you still interested in crafting keys for other AZ users? Does anyone else have an update with this particular project? This seems like the hottest, if not the best mod for the 04-06 TL's =)
Cant wait to see what you guys come up with, wish i could do all this myself unf =(
#293
Trucki!!
I still think this is possible to mill the keys, but I'm very interested in the molding aspect. But what are the molds going to be made of? Steel? Is it going to be as dense and not soft metal? I have no experience in molds, exept the molds we made in high school jewelry class out of pewter. Very high melting points for these harder metals. This would more than likely be the cheapest route to go if someone could develop a mold that is the entire blank + the plastic part.
#294
I should have a key in hand within a week. (according to the dealership ) We'll see.
#295
If it were me... I would cast the key blanks out of brass and have them plated. Much more cost effective than trying to duplicate the original.
#296
Ryan Christopher
Pete
Pete
#297
Trucki!!
The '07 key is what's commonly refered to as "insert molded" also called "over molded". IMO the only reason for this is so that the chip can be embedded into the plastic.
#300
Found the Simpsons episode where the key reminds me of the robot
http://www.youtube.com/watch?v=4X8FTz3PUks
#301
Ok, when I think of what the mold would look like. I think of how they make bullets, having the melted metal poured into a metal cast. Am I far off?
That works great for metals like tin and lead. Most keys are made of brass which has too high of a melting point. The most cost effective way (and you know I'm giving away all of my trade secrets here...) is to investment cast the keys.
You would create a master part and then create a silicone mold from the master. Once you have the mold you create wax patterns by injecting hot wax into the mold. Next you attach the wax patterns to a tree. See below...
The tree is then either coated with ceramic or in the case of the above tree, a steel sleeve is placed over the tree and a plaster of paris like investment is poured in. Once dry the rubber base is pulled off and the wax is melted out in a oven. Next pour in the molten metal of your choice. When it's cooled... you break off the investment and VIOLA!!!! Keys!!! or rings in the above case.
#302
Originally Posted by BG74
I think you guys might be wrong on your milling idea...I got my key today, and my '05 key is about 2 mm thinner in width (not thickness). I don't see a way to correct for it.
#304
Originally Posted by Black_05_TL_6SP
He uses a silcon to create the mold, then poors a ABS resin into it.
ABS is a thermoplastic, meaning that you'd have to get it molten first then inject it into the mold. My guess is that he uses polyurethane which when cured is a lot like ABS.
So... what are you going to do once you have a plastic key in your hand?
Somehow it's got to turn into metal or it just won't last.
#305
someone get this man a 07 Key Blank.................
#307
Ryan Christopher
Are you sure he uses ABS?
#308
FOR SALE - BM
Hehehe... You are way off.
that technique is very similar to dentistry and that is how they make Crowns and partial frameworks.. but in order to melt a key which is probably not a hard metal.. you will need a gas/oxygen torch and then probably centrifuge it into the mold.. but oxygen and centrifuge will add a lot of impurities and it will be fairly rough. once you get the roughness out and polish it , the key will probably be smaller... i see a better technique in putting the metal into a melting cup and getting it to a liquid form, then pouring it into the mold. that way you will eliminate at least some of the impurities that could be potentially adverse to making this mod.. i am curious though to see how you make it, and i would love to be proved wrong.
#309
As long as the '07 key blank is larger than an '04-'06 key blank then there's no problems. You can always easily remove metal. ...adding it when there's not enough is another story.
#313
While it is fun to speculate on how exactly one would go about casting a key and which methodology is best... it's much more cost effective to just send a CAD file and drawing to a short run casting house. They'll take care of all the details.
No need to re-invent the wheel.
#314
#315
I see a few different methods going on here. But I think whoever gets this figured out first will reap the rewards. Not only are TL owners wanting this in swarms, but TSX owners are buzzing about it. So this is almost a race to see who is going to make the $.
There are many many ways to get the '07 key to work. As a few have found out already, it's not just a simple chop and glue job. It'll take some trial and error to get to a really elegant, robust and cost effective solution. IMO... the person that comes up with a solution that encompasses all three variables will be the one that people will go to. Quality always wins out.
#316
Trucki!!
The real challenge will be getting swarms of key fobs for the swarms of people wanting them.
But I guarantee you who ever comes out with the first solution that WORKS will get the bulk of the business.
#317
Ryan Christopher
The way I am thinking of doing this, is to just sell a blank key with the plastic attached to it. You will still need to get a key from the dealer or whoever the supplier is. Then you can either remove the transponder from the 07 plastic part of the key, and insert it back into the new one and have the dealer program the transponder to the car. Programming the remote to the car is easy; it’s the transponder that has to be done by the dealer or someone with the tool. The other option will be to remove the transponder from the current key you have and insert that one into the new blank.
Or if one wishes, I can do all of it, but charge accordingly. I can get the fob, insert the blank and the transponder. Once the key is received, it will need to be cut and programmed to the car.
Let me know which way people would prefer.
#318
Trucki!!
I have already removed the immobilizer from my valet key, that I use in my Accord Fob. Whats the time frame your looking at? I got my key yesterday and its already burning a hole in my pocket.
Hell I'd be interested in just getting the plastic part, I can do the key myself
#319
#320
Ryan Christopher
I'd be interested in getting just the blank with the plastic around it
