2007 TL-S Fog Light Replacement
B16 Swapped TL
Ok one of the first things I decided needed to happen with the new TL, after seeing the headlights and foglights on at night, was replace the Yellow fog light bulbs with a silverstar or something comparable.
The bulbs are clearly a 9006 bulb, but the twist and lock mechanism is mounted higher on the bulbs that come in the TL stock. So the question is, where do I find replacements?
Picture below illustrates what I am describing
THE PLANE TAKES OFF!!!!!
They're H8/11 bulb size...
I have the yellows, like you can see in my Avatar. Mine are HID's though, with a layer of clear guard yellow film on top also!
B16 Swapped TL
Originally Posted by blazinginder
Hey guys, I was wondering, what work needs to be done in order to remove/replace the foglight bulbs...as in amy removal of the bumper etc.
In my 07, there are splash guards underneath held in by 3 or 4 bolts. Remove the bolts, twist the bulb, unplug the bulb, and then do the reverse.
thanks sporklover...I too have an 07 TL-S...did you have the "add-on" splash guards installed, or are you talking about the standard pieces in the wheel well (I apologize in advance if I'm confusing etc)
Originally Posted by XxAfG786xX
i got the nokya hyper yellows but damn how did you get yours to be so bright??
A J35A8 EG civic is in
B16 Swapped TL
They're HID lights... which are about 3x as bright as halogens. They look great!
where did you get yellow hids for? and thats hid fogs?
It's best to use the relay kit the lights come with, and run new power and grounds to the lights. I have them wired to come on with my headlights, since I never really turn them off.
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
