2006 TL mounts
Old Oct 23, 2013 | 01:44 AM
barewire001's Avatar
9th Gear
2006 TL mounts
hello all
Looking to save some money
I have already replace One engine mount next too the window wisher fluid i replace... I think its call the front engine mount..
I need to replace the other 2 engine mount...
I also need to replace my Transmission mount too
The car is 2006 86,000 miles the other mount were stock with the car and have not yet replace...
Can some tell me where to buy the parts and part number
rockauto ?
thanks
thanks
Old Oct 23, 2013 | 02:26 AM
paperboy42190's Avatar
rockauto will only have aftermarket ones. oem will be more expensive but when it comes to motor mounts i would always choose oem
Old Oct 23, 2013 | 02:27 AM
I'll leave this here, but I wont post the exact part numbers, I cant do all the work for you.
http://www.acurapartswarehouse.com/P...=true#partlist
Old Oct 23, 2013 | 03:30 AM
MandoTL's Avatar
Oh reminds me I need to order some again, stupid idle vibrations are still present, maybe the ones I just installed are faulty.
Old Oct 23, 2013 | 06:14 AM
MacKenzie001's Avatar
Just get the XLR8 mounts, replace em once and never worry again.
Old Oct 23, 2013 | 07:24 AM
losiglow's Avatar
There are several options on eBay but I'm not certain if they're rebuilds or aftermarket or what. They look identical to oem and they're a lot less expensive, that's for sure.
Something like this:
http://www.ebay.com/itm/03-07-Honda-Accord-3-0L-Transmission-Engine-Mounts-Hydraulic-6-PCS-Kit-0037-/251280057904?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ATL%7CYear%3A2006&hash=item3a81756630&vxp=mtr
I'd check the reviews though. The last thing you want are bum motor mounts.
Old Oct 23, 2013 | 09:07 AM
aIRpeACE's Avatar
stick with oem because you save more money in long term
Old Oct 23, 2013 | 02:30 PM
MandoTL's Avatar
This^
I have always purchased OEM mounts, but they last about 1.5-2 years max.
I dont know why they go out so fast, I never drive my car hard ALL the time lol..
But it gets annoying as its always the front one to go out first.
Old Oct 23, 2013 | 02:33 PM
^thats because if you look at the design of the mounts, they arent very stout...
even honda civic si's have better designed mounts than we do.
a '99 Chevy Malibu with 150hp has stronger mounts than we do.
I strongly recommend the XLR8 mounts, because the design is different while still utilizing the factory mount points
Old Oct 23, 2013 | 02:37 PM
MandoTL's Avatar
yeah the look poor made, but I thought the ones being sold now were improved compared to the originals?
So its like $300 off their website for the 3?
Old Oct 23, 2013 | 04:32 PM
Excelerate's Avatar
Former Sponsor
http://hoa.excelerateperformance.com...i-1804871.aspx
Old Oct 23, 2013 | 06:05 PM
MandoTL's Avatar
I checked your website out. So its front, rear and side.
Why do they look shorter? I may just order these rather than the OEM through my dealer, but they are always good to me with discounts.
see the pivot points through the center of the bushings?
its intended to move with the engine, whereas the factory mounts dont move and eventually will break through the center.
The side mount IS SHORTER. you'll have to buy washers or get the correct sized bolts. I used washers on mine and while it looks ghetto as fawk, it does the job just fine.
Old Oct 23, 2013 | 07:18 PM
MandoTL's Avatar
yes, I see.
It looks shorter, was it difficult to get the washers and bolts to fit properly? Just want to see how much trouble of doing it, since my uncle will be the one to install he is very busy and hates to spend too much time to get washer/bolts to fit and line up.
But he does great work with taking enough time to install parts for me or I'll be upset.
Old Oct 23, 2013 | 09:08 PM
if he gets the correct bolts, which are identified in another thread here on acurazine, all he would have to do is bolt the side in, just like normal.
Old Oct 24, 2013 | 12:16 PM
Excelerate's Avatar
Former Sponsor
Yes. They are a direct replacement mount. It's the same height.
We actually include all the hardware now. It has the correct size bolts for the side mount.
Old Oct 24, 2013 | 12:17 PM
Would you be a doll and send me the bolts?
I ordered less than a month ago!
Old Oct 24, 2013 | 01:17 PM
MandoTL's Avatar
Good to know, I'll still think about it as I just replaced my motor mounts like 3 weeks ago, and the front one is out. but side and rear are fine.
Idk how the front can go out so fast unless it was defective.
Old Oct 24, 2013 | 02:20 PM
anx1300c's Avatar
I don't know how some people go through mounts like I go through underwear and others have no issues. My car has full bolt ons, I take it to the track a lot and mine were still good at 93k.
Old Oct 24, 2013 | 02:33 PM
softer means more comfort though, and most car buyers prefer that
Old Oct 25, 2013 | 11:04 AM
Excelerate's Avatar
Former Sponsor
PMed.
Old Oct 25, 2013 | 11:28 PM
Gil'sUA5's Avatar
I was gonna go with OEM but i believe the XLR8 mounts will last longer, they definitely look like they are built better and they happen to be cheaper. I just hope they aren't too stiff so i don't feel any vibration from the engine because some aftermarket mounts can be a bit stiff, but those are the only ones i'd take over OEM.
Old Oct 26, 2013 | 07:12 AM
^75a durometer's arent bad at all.
a little vibration, inside the cabin with the A/C on.
passengers can feel it at stop, but it isnt like a built subaru, where its motherfucking racecar status....
the 75a's still retained luxury feel, just a little more pronounced.
seriously, its not bad at all.
My friend drove my car the other night and laughed.
why?
because he thought it was going to be a Michael J. Fox up in that bitch.
lol, its not.
Old Oct 26, 2013 | 09:02 AM
Aftermarket mounts on a manual is no big deal. However on an auto it's usually not preferred. Unless you really want to go race car status
Old Oct 26, 2013 | 09:04 AM
If you really don't want to feel "any vibration" like you said, then you will NOT be happy with the aftermarket mounts. The car will idle like all your mounts are broken. But driving wise it'll feel great.
Old Oct 26, 2013 | 03:47 PM
xxx_busa's Avatar
I didn't receive mine. What happen to my bolts, Mark Melheim, you have the address.
Old Oct 26, 2013 | 10:53 PM
Gil'sUA5's Avatar
Ahh i see, yea I'm picky with the vibrations i like the feeling of no feeling when I'm inside the car. So OEM it is
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
LeVeL
Oct 18, 2015 04:19 PM
Froid
Sep 27, 2015 06:16 PM
