2006 Starter
Old May 6, 2023 | 06:58 PM
Midnightbui's Avatar
8th Gear
2006 Starter
My car is having trouble starting. Battery level is good so Its not that or alternator etc. I read changing the starter is pretty easy. My question is being that its a 2006 where do you recommend getting a starter at. Carquest, O'Reilly, autozone etc. Or go OEM? Thanks in advance.
Old May 6, 2023 | 07:09 PM
BillMFD3's Avatar
I went with Denso reman off rockauto
car had 255000 miles at the time
Old May 6, 2023 | 11:41 PM
8th Gear
Mine is at about 217,000. Hows it holding up with the Denso
Old May 7, 2023 | 05:18 AM
BillMFD3's Avatar
no issues, at 268000 now
took about an hour to replace in the driveway
good luck
Old May 7, 2023 | 02:41 PM
boukante's Avatar
8th Gear
My 2006 starter started acting up a few years ago. I changed the starter and the issue persisted. It turned out to be the ground strap to the chassis near the battery. It was lose and there was some corrosion. Clean and tightened it and the starter has been fine since.
Old May 26, 2023 | 10:48 AM
tonialandry's Avatar
good luck
Hello,
I want to replace my starter. I've seen some videos on youtube that show how to do it. But I don't think I have the right tools. Did you have to lift your car to change the starter? I don't even have a jack to lift it. I am open to ideas.
Old May 26, 2023 | 07:35 PM
BillMFD3's Avatar
Yes I removed the battery tray as there is a bolt on the underside
you might reach it from the top but I did jack up my car. No special tools other than sockets and wrenched
acj003
Oct 24, 2020 06:16 AM
delslow
Mar 23, 2019 08:20 PM
pdemulli
Apr 16, 2017 10:46 PM
rcljrmann
Mar 9, 2017 03:06 PM
convejos
Oct 10, 2014 07:33 PM
