2005 Auto TL Questions.
Ryan's loving his ATLP TL
I have some questions. I have owned my 05 Auto TL for just over a month now and I have done the following modifications to my car.
Replaced engine oil with Synthetic Oil.
Put an AEM Cold Air Intake.
Replaced and flushed Anti-Freeze.
Now I am curious. I have just about 74,000 Miles on my car. And we all know how dealerships are. What should I do to my car to keep it running at its best. The TL's that have had Transmission Failures, would mine of been effected already if it was one of the EFFECTED?
What are things I should keep an eye out for?
And IF I go to my local Acura Dealer and tell them about the recalls, will they replace all of them for free?
Sorry for all the questions guys! :P But thanks for reading.
There's no way to tell the transmission was serviced unless you knew the last owner. I would have the fluid drained and refilled a few times just to have peace of mind.
Also, at that mileage I would replace the cabin air filter and have your timing belt and drive belt inspected.
Transmissions are fine for 05. it was the 1999-02 and some 03's and some very early 04 that had the issues with the transmissions. Replace the serpentine belt and rat hoses. Flush the brake fluid.Replace the filters. And watch the tires especially if they are the bridgestones. Rotate and do the allignments regular.
Rotate tires
Replace air cleaner element
If you drive primarily in dusty conditions, replace
every 15,000 miles (24,000 km).
Replace dust and pollen filter
If you drive primarily in urban areas that have high
concentrations of soot in the air from industry and
from diesel-powered vehicles, replace every 15,000
miles (24,000 km).
Inspect drive belt
Replace transmission fluid
Driving in mountainous areas at very low vehicle
speeds results in higher transmission temperatures.
This requires transmission fluid changes more
frequently than recommended by the Maintenance
Minder. If you regulary drive your vehicle under these
conditions, have the transmission fluid changed at
60,000 miles (100,000 km), then every 30,000 miles
(48,000 km).
Replace spark plugs
Replace timing belt and inspect water pump
If you drive regularly in very high temperatures (over
110°F, 43°C), or in very low temperatures (under-20°F,
29°C), replace every 60,000 mile (U.S.)/100,000 km
(Canada)
Inspect valve clearance
Replace engine coolant
I had it done at Acura @ DCH Acura in Wappingers falls It was $99.95.. Ryan. I would not go to any place like Jiffy Lube, or of the like. Where in Upstate, are you?
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
