2004 TL Switchblade mod
So i have a great opportunity to get a cheap and relatively good condition switchblade key for 40 bucks. I've seen the thread in which the old non milled key is hacked up and one of the spares is glued in ( which does not worry me at all ). Im just wondering if i have to match my FCC ID for me to be able to program the key to my door locks.
Yes make sure you get the right FCC ID.
It's on the back.
It's on the back.
It will work.
The one that don't work (and is popular on ebay) is mlbhlik-1t
I'm using 439H-A with my 04 TL.
Domain007 (01-03-2015)
Let me know if you need any pointers.
I've converted 4 keys to switchblades, and learn something new each time to make the conversion the best.
So amazingly, i got my fob in today and started work right away. I cut the key, programmed the remote with only running into a small problem. The studs (little black pegs which the key holds on to). I have no idea what size drill bit i have to use for them. My best guess would be a 1/16th of an inch, but i could always be wrong.
I didn't even use those.
I broke them all off when I removed the key that came with the switchblade.
JB-Weld is much better, holds everything in place even without those little studs.
Beautiful.
Congratulations, you saved a lot of money doing the conversion
can you provide a writeup of all the steps and p/ns?
So can you use any 2007-2008 switchblade, don't you need to get a blank to get it cut correct since ours is the old style blade.
https://acurazine.com/forums/first-g...photos-671520/
The DIY I followed completely.
One thing that won't be perfect is the open and close slot of the key as the DIY mentioned.
It'll either hang out of the holder, or it will open too far.
The DIY mentions to make the slot "walls" of JB Weld.
After doing a few conversions, I did some things my own way, simply because the JB Weld "wall" does not hold longer than a couple months, if even that.
Buy any switchblade that has the same FCC ID, off ebay.
Find one preferably with buttons that aren't worn off.
I've been always able to find good condition (like new) switchblades off ebay for around $30.
It's probably one of my favourite mods, makes the car seem new again every time you use the key.
To rectify the issue of the key opening too far, as seen here:
Keep the "stop" of the switchblade key.
A small part of the metal blade stops the key from opening too far.
When you remove the blade and put in your own blade, you get rid of that small part.
What I did was remove the blade but I cut the portion of the "stop" and kept it there.
Fool proof way and will never over-shoot.
You can see the metal blade portion that stops the key from overshooting in this picture: look on the right side, between the two circle markings.
You can see the difference between the two blades, and how the "original" blade has the "stop" portion. Look between the two "drill holes" on the left.
You can clearly see in this picture (between the two studs) how his new blade is now missing the big chunk of metal that stops the over-shooting.
In this picture he tries to rebuild that "stop" out of JB-Weld.
After remaking that wall of JB-Weld 3 times, I finally came up the method to cut the portion off the original blade with the stopper and place it in.
How is metal fit into a super tight plastic molding, held together with JB weld flimsy to you ?
Even if there there was no JB weld, the metal is in it's super tight "channel" and would not move.
Not to mention there's also studs. Also worth mentioning JB Weld and flimsy don't go together
Maybe it's one of those things where you actually have to be working on it to understand.
polobunny (01-13-2015)
Registered Bunny
Make so much more sense now, I knew there's something I wasn't getting. As said, easier to understand once you've worked on it.
GWEEDOspeedo
01-15-2016 10:39 PM
InFaMouSLink
10-27-2015 06:52 PM
TLguy42
09-26-2015 11:27 AM
