2004 TL Headlight Change Question
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Anyone aside from me think headlights will be nearly impossible or very time consuming to upgrade/change now that they are behind the 1/4 panels and not the hood?
I have been planning my foglight upgrade when I get the 04 and think I may not be able to get to them.
Re: 2004 TL Headlight Change Question
Never thought about it, but since you brought it up, it seems yes it would be hard to do many mods to the car
What type of upgrade are you thinking of? HID? or silver stars or brighter halogens?
Retired MOD
1 Post
Re: Re: 2004 TL Headlight Change Question
Originally posted by Bitium
Maybe they did it that way so is harder to steel !!!!!!
I was just wondering how Acura Protected there Headlights for this Genearationg
Originally posted by huskerfan
Low, High, and fogs are all HID and in one unit. They are controlled by a shutter system.
Re: Re: Re: 2004 TL Headlight Change Question
Originally posted by 2004TL
Are you sure Fog is also Xenon Bulb (HID)?
"HID (HIGH-INTENSITY DISCHARGE) HEADLIGHTS
Previously, the TL had HID (High-Intensity Discharge) low beams coupled with conventional halogen high beams. The new TL headlights feature HID high and low beams, as well as built-in fog lamps. These bi-function HID high/low beams are made possible by a shutter device that mechanically controls the light output of the HID unit. When the driver selects high beam, an electric solenoid in the headlight moves a shutter forward, opening up a greater reflector area inside the headlight. When the lights are operated on low beam, this shutter repositions to act as a cut-off to keep the lighted area closer to the vehicle.
Compared to the previous TL, the new headlights dramatically increase the illuminated area, and are nearly 50 percent more effective at long range. The fog lamp illumination has also been increased."
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Re: Re: Re: Re: 2004 TL Headlight Change Question
The fog bulb is HALOGEN!
I can't imagine the fogs being hid's it would be too bright and would blind people
AndrewS
19
03-14-2024 06:59 PM
tman570
06-11-2019 07:56 AM
