2004 TL Headlight Change Question
Old Sep 21, 2003 | 12:40 AM
EmuMessenger's Avatar
Lightbulb 2004 TL Headlight Change Question
Anyone aside from me think headlights will be nearly impossible or very time consuming to upgrade/change now that they are behind the 1/4 panels and not the hood?
I have been planning my foglight upgrade when I get the 04 and think I may not be able to get to them.
Old Sep 21, 2003 | 12:56 AM
Raheel's Avatar
Re: 2004 TL Headlight Change Question
Never thought about it, but since you brought it up, it seems yes it would be hard to do many mods to the car
What type of upgrade are you thinking of? HID? or silver stars or brighter halogens?
Raheel's Avatar
Actually Wouldn't making the Fogs HID be illegal?
Thats 4 Xenon Bulbs..
Old Sep 21, 2003 | 07:45 AM
Bitium's Avatar
Retired MOD
Maybe they did it that way so is harder to steel !!!!!!
Old Sep 21, 2003 | 09:33 AM
Just thinking about a yellow bulb installation. Looks light it will be more than a 10mm wrench.....
Old Sep 21, 2003 | 03:35 PM
Raheel's Avatar
Re: Re: 2004 TL Headlight Change Question
WOW good guess...
I was just wondering how Acura Protected there Headlights for this Genearationg
Old Sep 22, 2003 | 05:42 PM
ressum's Avatar
6th Gear
Actually the 2004 is equipped with low AND high beam HID headlights as standard equipment
Old Sep 22, 2003 | 05:50 PM
huskerfan's Avatar
Low, High, and fogs are all HID and in one unit. They are controlled by a shutter system.
Old Sep 23, 2003 | 02:49 PM
Raheel's Avatar
Are you sure Fog is also Xenon Bulb (HID)?
Old Sep 23, 2003 | 03:08 PM
huskerfan's Avatar
Re: Re: Re: 2004 TL Headlight Change Question
Can't tell from the write up below. They say the Fog Lights are built into the HID unit, but whether they are separate bulbs or not I can't tell. Quote from Honda news:
"HID (HIGH-INTENSITY DISCHARGE) HEADLIGHTS
Previously, the TL had HID (High-Intensity Discharge) low beams coupled with conventional halogen high beams. The new TL headlights feature HID high and low beams, as well as built-in fog lamps. These bi-function HID high/low beams are made possible by a shutter device that mechanically controls the light output of the HID unit. When the driver selects high beam, an electric solenoid in the headlight moves a shutter forward, opening up a greater reflector area inside the headlight. When the lights are operated on low beam, this shutter repositions to act as a cut-off to keep the lighted area closer to the vehicle.
Compared to the previous TL, the new headlights dramatically increase the illuminated area, and are nearly 50 percent more effective at long range. The fog lamp illumination has also been increased."
Old Sep 23, 2003 | 07:28 PM
The fog bulb is HALOGEN!
Old Sep 24, 2003 | 01:11 AM
Raheel's Avatar
Re: Re: Re: Re: 2004 TL Headlight Change Question
THank you, that is what I thought..
I can't imagine the fogs being hid's it would be too bright and would blind people
AndrewS
19
Mar 14, 2024 06:59 PM
tman570
Jun 11, 2019 07:56 AM
eastcoastguy
Sep 24, 2015 02:07 PM
acuraST
Sep 17, 2015 02:31 AM
Aleax
Sep 11, 2015 11:31 AM
