2004/AT ASpec Brakes
OK, explain this one....
I drive AT (not by choice...but since i dont have money im not complaining)...anyway, when I need to make a rough stop, (ex. hitting 80 and needeing to stop within 150ft cuz of the traffic light, or ex 2, hitting 80, and trying to make a turn you forgot about...) anyway, when you hit the brakes on the AT, it "clicks?", as if the brakes arent strong enough..as the owner of a recent TL, it scares the hell out of me...(are my brakes messed up?) ~~ i also drive a G35 Coupe and the brakes on that G35 are fine! I do the same crap and i stops as if I was driving 10 mph....what's going on?
Are you braking so hard that the ABS is activating? That would feel like a pulsing or clicking. You may want to go to an open area (no cars) and do some hard braking runs to get a feel for when ABS is kicking in and what it feels like. I haven't driven a 5AT A-Spec, but I'm guessing the transition from hard braking to ABS-activation may happen more rapidly.
The Brembos give very fine control over pedal application. I'm sure there will be aftermarket Brembo options before too long for your car.
Yeah that sounds like ABS, which is just stupid because you shouldn't have to brake that hard unless its an emergency. Maybe you should try remembering your turns and not driving 80 in traffic.
With the performance pads installed, the transition from 'hard braking' to 'ABS activated' may be more sudden and harder to modulate. Practicing will help with controlling this. Also, remember that the TL has brake assist and 'learns' your braking habits. Harder than normal braking can trigger ABS even if it's not 'pedal to the floor' braking. Practice and consistency will help keep this from happening.
Of course, if he has sufficient braking power with his current brakes to invoke the ABS, he won't be stopping any faster unless and until he gets fade such that he can't get into the ABS any more... Just a thought!
<TED>
<TED>
Is there really any parallel between me not knowing what a headliner is and this guy going 80 in traffic, forgetting a turn, and then slamming on the brakes?
ok so if it IS the ABS, how do I get used to it? The Drive by wire throttle system really screws up my "feeling" of the pedal...although its more comfortable, its hard to "measure" ~ (well i've had the car for less than 3 months, maybe more practice?)
o yea what IS a headliner?
btw GaleForce ur comparing skills to head knowledge thats stupid....no hard feelings though...
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
